Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Mismatched output from successful parallel run
Old   January 16, 2012, 12:44
Default Mismatched output from successful parallel run
Edwin Lee
Myoldmopar is on a distinguished road
Greetings:
I am currently resolving a separate problem related to transferring files over multiple machines during a successful parallel run with OpenFOAM:
http://www.cfd-online.com/Forums/ope...allel-run.html
I encountered what I believe is a separate problem during this investigation. A quick summary: I am on computer "A" and running a simulation using 8 cores of "A", and 8 cores each on "B", "C", and "D." The simulation runs without warning, and I note the usage of each machine ramp up fully and output is generated on each machine.
The current problem is that computer "A" is missing a bunch of the time folders! Since there are four machines, deconstructPar gives each fourth processor folder to a separate machine. So "A" is in charge of "processor3", "processor7", etc., for my setup. While "B - D" all have the entire set of run times based on my output interval, "A" is missing a bunch of them...
While "B - D" all have the data at every timestep desired, "A" has it at that time step interval for a while, then appears to extend the duration between reporting steps! I can happily list the output, but didn't want to clutter this up too much since I am a lengthy poster as it is...sorry.
Thanks for any guidance!
Myoldmopar is offline   Reply With Quote
output data, parallel computation, reconstructpar, time st
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 23:51
Parallel run in fluent for multiphase flow apurv FLUENT 2 August 3, 2011 20:44
First Parallel Run - need some help Gian Maria OpenFOAM 3 June 17, 2011 13:08
parallel run for fsi simulation??? smn CFX 2 July 19, 2009 05:04
How to run parallel in ICEM_CFD? Kiddo Main CFD Forum 2 January 24, 2005 09:53
