July 13, 2011, 06:23 |
Interpreting PatchIntegrate Data
Gabbee
Rep Power: 15 |
I am new to CFD let alon OpenFOAM and am having difficulty interpretting data. I have ran an axisymmetric SimpleFOAM model and am checking for consistency, I used the "patchIntegrate phi Inlet" and "patchIntegrate phi Outlet" commands for openfoam 2.0.0. I get different values for the integral over phi however the magnitude of areas is also different for inlet and outlet. If i divide the integral of phi value by the area for both the numbers I get 9.523 for outlet and 3.997 for outlet. Does the differences in these numbers mean the model has not converged properly? Sorry this post is a little confusing I am not sure how to express this correctly with the little knowledge I have Regards Gabbee |
December 5, 2014, 16:45 |
Hello Gabbee
Its been a long you have posted about patchIntegrate phi inlet/outlet problem. I am also facing a somehow similar problem. I am using OF 2.3.0, my inlet and outlet area is same but flow rate are different for inlet and outlet when I use "patchIntegrate phi inlet/outlet" Regards |
【Help】"Error: Update_Time_Level: invalid data" | Chen | FLUENT | 2 | August 24, 2014 08:51 |
export data at nodes | Meenu | FLUENT | 1 | December 30, 2011 02:24 |
CGNS vs Tecplot Data Format | LWhitson2 | Main CFD Forum | 3 | July 1, 2011 14:50 |
Saving particle (DPM) data to file? | Philip | FLUENT | 2 | June 12, 2006 02:41 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
