Is the sample utility compatible with chtMultiRegionFoam |
Mirko Vukovic
Rep Power: 17 ![]() |
I am running an example of chtMultiRegionFoam provided by Lars (see this post) I tried running the sample utility on the results. The utility runs for all the saved time steps (0 to 30.001) but the sets directory contains only the 0 subdirectory, and none other. Thanks, Mirko |
Thiago Vetter
Rep Power: 15 ![]() |
My experience is with the probes functionObject from the sampling library.
Assuming the subject is the same, the 0 subdirectory contains a file for each monitored field (such as U or p) and each of these files contains the entire time series for that field at that point. Hope that was helpful. |
Mateus Palharini Schwalbert
Hello, Mirko. Have you managed to solve your problem with sampling in multi-regions? I'm having the same problem. Actually, if you use the sample command with the option [-region], you can sample each region, but I can't sample U components, 'cause foamCalc does not work with multi-region... can you help me?
Daniele Dovizio
Hi mateusps,
I just started looking at chtMultiRegionFoam and was wondering the same thing. How would you sample your data when you have multiple regions? I am running the planeWall2D tutorial https://openfoamwiki.net/index.php/G..._-_planeWall2D In paraFoam I can plot over line the temperature profile crossing the three regions (topAir, wall, bottomAir). Do you know a way to get the same sets of data with sample utility? Thanks, Daniele |
Adkar
Rep Power: 11 ![]() |
sample -region regionName
cheers |
Sample Utility not working in OpenFoam 1.6 | titio | OpenFOAM Post-Processing | 6 | November 15, 2014 18:04 |
Sample utility not working properly | titio | OpenFOAM | 2 | June 9, 2010 10:45 |
Understanding the coordinates of sample utility | vishwa | OpenFOAM Post-Processing | 4 | March 25, 2010 12:51 |
Sample Utility not working in OpenFoam 1.6 | titio | OpenFOAM Post-Processing | 0 | February 5, 2010 12:12 |
Sample utility not working in OpenFoam1.5 dev | titio | OpenFOAM Post-Processing | 1 | December 10, 2009 02:38 |
