Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to calculate a zone Average
Like Tree13Likes
Old   November 14, 2012, 18:41
Assistant Moderator
Bernhard Gschaider
Originally Posted by aerogt3 View Post
I just download swak4foam, and right now I just want to get the average pressure and total mass flow rate at my velocity inlet, to compare with hand calcs and make sure I am using it correctly. To sum these, I am doing the following:
            mdot_inlet
              type swakExpression;
              valueType patch
              patchName inlet
              expression "phi*flip()";
              accumulations
                  sum
              verbose true;
            p_inlet
              valueType patch;
              patchName inlet
              expression "p";
              accumulations
                  average
              verbose true;
I get the following error for averaging p, and I get the same error when performing the operation on faceZones.
[44] [24]
--> FOAM FATAL ERROR:
[42] --> FOAM FATAL ERROR: Could not find a field name "p" of type scalar (neither surfaceScalarField nor volScalarField) Autointerpolate: 0
[16]
And this one for mass flow rate. When I do mass flow rate calcs on faceZones, it works.
[42]
[42] Parser Error at "1.5-8" :"field flip not existing or of wrong type"
"phi*flip()"
Any ideas? As best I can tell, I am following your syntax correctly, no?
Average pressure should work ... if there is a field p. Which solver are you using
About flip(): you only need that on faceSets and faceZones. On patches the orientation of the faces is defined (all looking "in") and therefor flip() is not implemented for patches
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   December 6, 2012, 14:13
Brock Lee
GRAUPS is on a distinguished road
            mdot_inlet
              valueType patch
              patchName inlet
              accumulations
                  sum
              verbose true;
            p_inlet
              valueType patch;
              patchName inlet
              expression "p";
              accumulations
                  average
              verbose true;
Looks like he is missing some semicolons after the patch name? Try that, i think it might solve your problem aerogt3.
GRAUPS is offline   Reply With Quote
Old   December 6, 2012, 14:35
Assistant Moderator
Bernhard Gschaider
Right. I never look for the obvious. Nevertheless: it is strange that it "found" the expression that way
Old   December 12, 2012, 13:00
aerogt3 is on a distinguished road
Thanks for the reply! I have given that a try, and for a patch, it works correctly. I can successfully monitor patch average pressure, thanks!
On a faceZone however, I am not able to do it. I get the error:
I think this is because p is simply not calculated on faceZones, and only in cells and on walls. Is this correct, or am I using the tool incorrectly?
aerogt3 is offline   Reply With Quote
Old   December 12, 2012, 13:56
Assistant Moderator
Bernhard Gschaider
Yep. But if you set autointerpolate (not sure about the capitalization. Look at the examples) to true then swak interpolates it to the faces in the zone (the error message is not correct "nor volScalarField" but at least it tells that autoInterpolate is not set)
Old   December 12, 2012, 16:11
Brilliant! What a clever option, thank you so much!
Old   December 12, 2012, 17:17
Assistant Moderator
Bernhard Gschaider
Well. Without it computations on faceZones/Sets wouldn't make much sense, would they It is not set by default so that users at least in theory acknowledge the fact that this is not the "real" value but only an approximation
Old   December 13, 2012, 11:58
True, having had to find and turn on the flag I am now very aware that its an approximation
I think it's relevant to this thread, but is it possible to calculate the integral of a scalar field's gradient over a cellZone? I have tried below, but it's not working. Perhaps a matter of syntax, or maybe am I attempting something that's not possible?
functions
   grad_integral
        valueType cellZone;
        zoneName fluid_2;
        accumulations (
            sum
        expression "grad(p)*vol()";
        verbose true;
Old   December 13, 2012, 12:55
Assistant Moderator
Bernhard Gschaider
functions
   grad_integral
        valueType cellZone;
        zoneName fluid_2;
        accumulations (
            sum
        verbose true;
That should be possible (haven't tried it but it looks OK, assuming there is such a zone). Could you be more specific about the "not working"-part?
Old   December 13, 2012, 13:09
Certainly! The zone definitely exists, so here is the error output. It looks to me that I am just not writing grad correctly, so wrong syntax?
Expression grad_integral :
 Parser Error at "1.1-4" :"field grad not existing or of wrong type"
"grad(p)*vol()"
    From function parsingValue
    in file lnInclude/CommonValueExpressionDriverI.H at line 802.
FOAM exiting
Old   December 13, 2012, 17:29
Assistant Moderator
Bernhard Gschaider
"grad(p)*vol()"
FOAM exiting
Sorry. My bad. Didn't look too closely the first time: "grad(p)" does not work on sets and zones. The reason is that OF only implements the differential operators for whole fields. The options to get that behaviour would be:
a) reimplement major parts of OF to work on sets and zones. Too much work (unless somebody pays for it)
b) calculate a temporary field "grad(p)". Get the relevant values from it. Throw it away. Could be done but would have major performance implications "grad(p)+grad(p)" in a 100 cell cellZone of a million cell case would mean that the gradient is calculated twice for the whole mesh (and because of the transparent handling it is not obvious to the user why this is so slow). So: no
The proposed workaround is to use expressionField to generate a field gradP with the value "grad(p)" and calc "gradP*vol()" on the zone. gradP is still calculated on the whole mesh, but the user is aware of it and he can even reuse the field in other calculations
yanxiang likes this.
Old   July 3, 2015, 00:32
Default swakExpression error
  #32
Elham
Elham is on a distinguished road
I am a new OpenFoam user. I have modeled a single droplet falling in air and I want to calculate its velocity. So I used the following expression at the end of controlDict:
functions
downAverage
valueType internalField;
variables (
"downDirection=vector(0,-1,0);"
"thres=0.5;"
"liquidVol=sum(alpha.water>thres ? vol() : 0);"
"downVel=alpha.water>thres ? (U & downDirection) : 0;"
expression "downVel*vol()/liquidVol";
accumulations (
sum
verbose true;
But the following error appeared:
Unknown function type swakExpression
Valid functions are :
4
patchProbes
probes
sets
surfaces
From function functionObject::New(const word& name, const Time&, const dictionary&)
in file db/functionObjects/functionObject/functionObject.C at line 92.
FOAM exiting
I will really appreciate if you could tell me your idea to fix it.
Regards,
Elham
Elham is offline   Reply With Quote
Old   July 13, 2015, 04:02
Silvan
silvan is on a distinguished road
Did you run updateSharedLibraries?
Did you include the swak libraries in the controlDict?
please see http://www.cfd-online.com/Forums/ope...tml#post552461
Quick answer: Edit the "system/controlDict" and add the library "libsimpleFunctionObjects.so" in "libs" before "libsimpleSwakFunctionObjects.so", e.g.:
libs
silvan is offline   Reply With Quote
Old   October 14, 2015, 23:11
Dasein
Tellur is on a distinguished road
Hi Everyone,
I am trying to calculate area weighted average velocities on a certain level above the floor height. To do that I use the following topoSet dictionary:
actions
// Surface_1
name Surface_1;
type faceSet;
action new;
source surfaceToCell;
sourceInfo
file "Surface1.stl";
outsidePoints ((15 15 15));
includeCut true;
includeInside false;
includeOutside false;
nearDistance -1;
curvature 0.9;
name Surface_1;
type faceZoneSet;
action new;
source setToFaceZone;
sourceInfo
faceSet Surface_1;
After I've created my faceZone I use swak4foam to calculate the weighted average velocity, following the recommendations above:
weightedAverageVel
valueType faceZone;
zoneName Surface_1; // or whatever is your zoneName
accumulations (
min
//average
autoInterpolate true;
expression "sum(mag(U)*area())/sum(area())";
verbose true;
outputInterval 1;
outputControlMode timeStep;
The whole thing seems to work but I'm not sure if I can trust my results, velocities seem quite low. I can't help feeling that I've made a mistake somewhere in the math.
If anyone has used swak4foam for this before I'd be obliged if you pitched in.
Thank you in advance!
Kind regards,
Theodore.
Tellur is offline   Reply With Quote
Old   October 16, 2015, 01:23
Dasein
And one more question if I may. I looked around for this but couldn't find an answer. It is related to my very bad knowledge of C++ and coding in general but should be a novice question for the experienced people on this board.
I have a big number of faceZones I want to calculate parameters for.
Is there a way to list all the faceZones in one zoneName parameter? I tried the typical C++ list but wouldn't work. If this is possible, would it still create different post processing text files (I would prefer this)?
Furthermore, is there a way to list a number of expressions in one object? I would like to get the results of multiple parameters in one file instead of separate.
Thank you so much in advance and excuse my novice questions.
Kind regards,
Theodore.
Old   October 21, 2015, 00:55
Dasein
Hello again, I seem to have another issue although this is not related to swak4foam.
I am using the topoSet to acquire the faceZoneSets in which I want to use swak4foam to calculate my average velocity. I have one surface stl for each of the faceZones (imagine this is a plane 1.2m above the floor of my building in the model).
However, when I use foamToVTK to preview these zones, after they have been generated, I get a collection of cells that is ALL over the place and really nowhere near to where the surface is. The options I used are below:
name T1A_Bathroom1;
type faceSet;
action new;
sourceInfo
file "CalculationPlanes/Tower_1/UnitA/Bathroom1.stl";
outsidePoints ((50 50 200));
includeCut true;
nearDistance -1;
curvature 0.9;
name T1A_Bathroom1;
type faceZoneSet;
action new;
sourceInfo
faceSet T1A_Bathroom1;
I wonder if I am doing something wrong. I tried to go over relevant threads and dictionairies but I'm having trouble understanding the impact of the options like outside points (especially since this is a planar surface and curvature.
I should also stress that I already used includeInside true without much success. Is there something terribly wrong in my code or is it just a visualization problem?
I'd appreciate any wisdom
Kind regards,
Theodore.
Old   October 27, 2015, 10:30
Default How to calculate the sum of energy for a given zone?
  #37
Xiantao Zhang
zhxter is on a distinguished road
I use openfoam to simulate waves.
For example, the length of numerical wave tank is 20m, and from 15 to 20m is the damping zone. I want to calculate the whole energy in the zone from 0 to 15m.
Does anyone know how to do this?
zhxter is offline   Reply With Quote
openfoam 1.7.1, patchaverage, porous modellling, sampledict
How to calculate a time average spwater OpenFOAM 2 February 24, 2010 09:04
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
calculate the average velocity of particles robert FLUENT 0 August 1, 2008 10:44
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 09:42
Sliding mesh error Karl Kevala FLUENT 4 February 21, 2001 16:52
