Nadeem
Rep Power: 17 ![]() |
Hello everybody,
I am stucked to a simple problem and not able to find out a solution of it. I want to read gradient from another file and interested to write it into T (temperature file of OpenFOAM). I did like as below: volScalarfield field ( IOobject(fieldName,runtTime.timeName(),mesh,IOobje ct::NO_READ,IOobject::AUTO_WRITE), mesh, dimensionedScalar(fieldName,dimTemperature, 200), "fixedGradient" ); forAll(field.BoundaryField(),patchID) { field.boundaryField()[patchID]==30; } As an output of this code am getting something different. that is. boundaryField { Inlet { type fixedGradient; gradient uniform 0; } and so on; } but I am interested to get output as below: boundaryField { inlet { type fixedGradient; gradient uniform 30; } } I am sure am doing a mistake, and I think by using field.boundaryField()[patchID]==30; temperature at the patchID is getting stored, instead of temperature value, am interested to store gradient value. I shall be thankful for your kind replies. BEst Regards, |
field, fixedgradient, patchfield, volscalarfield |
if-loop, volScalarField comparison | volker | OpenFOAM | 7 | March 6, 2020 20:03 |
Problems with creating a volScalarField | georlade | OpenFOAM Programming & Development | 4 | December 4, 2016 12:31 |
An error has occurred when Writing backup file | tian | CFX | 0 | June 28, 2007 21:29 |
journal file command for writing mass flow rate | James | FLUENT | 0 | July 26, 2006 10:51 |
Fatal error error writing to tmp No space left on device | maka | OpenFOAM Installation | 2 | April 3, 2006 08:48 |
