Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
StreamFunction utility
Old   May 19, 2010, 17:04
Default StreamFunction utility
Antonio Martins
titio is on a distinguished road
Send a message via MSN to titio Send a message via Skype™ to titio
Hi foamers,
I am trying to calculate the streamfunction for a 2D steady state simulation, in order to calculate the values of the flowrate in particular planes of calculation.
I am using OpenFoam 1.5-dev, and the utility streamFuction. It works fine, but when I use the foamToTecplot utility, it does take into account the values of the streamfunction.
Thus, how I can force the foamToTecplot utility to use the values calculated by the streamFunction utility. On the other hand, how it is possible to calculate directly in OpenFoam the values of the stream function?
Regards,
Antonio Martins
titio is offline   Reply With Quote
Sample Utility not working in OpenFoam 1.6 titio OpenFOAM Post-Processing 6 November 15, 2014 19:04
problem with sampling Utility in openFOAM 1.6 carmir OpenFOAM Post-Processing 10 February 26, 2014 03:00
StreamFunction Utility in OF1.6 maruthamuthu_venkatraman OpenFOAM 5 September 28, 2011 10:28
UDF for streamfunction nisha Fluent UDF and Scheme Programming 0 September 15, 2009 07:55
streamfunction from u and v on a coarse mesh ryoga Main CFD Forum 0 February 1, 2002 19:20
