Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Simple plane sample not working
Old   May 16, 2010, 17:31
Default Simple plane sample not working
David Gaden
marupio is on a distinguished road
I don't get it. When I use the "basePoint" / "normal" to specify a plane, it fails silently whenever the Y-coordinate of "normal" is zero. That is, it runs, reports all the times, and completes, but there are no files in the surfaces/[time]/ directories. Here's my sampleDict:
setFormat raw;
surfaceFormat raw;
interpolationScheme cellPointFace;
fields
U
sets
surfaces
newPlane
type plane;
basePoint (5 2.5 5);
normalVector (0 0 1);
interpolate true;
triangulate true;
This produces no output. If I change the normalVector to:
normalVector (0 0.00001 1);
it succeeds.
Does anyone have any idea what is going on here?
(OpenFOAM 1.5-dev)
marupio is offline   Reply With Quote
Old   May 17, 2010, 03:48
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
it succeeds.
(OpenFOAM 1.5-dev)
The 1.6.x version has some code to handle cases where the cuttingPlane aligned fairly closely to a cell face (where the normal cell cutting algorithm would otherwise fail horribly) -- this is what the zeroish and positive local variables are about.
I don't know if the sourceforge svn version has this, do you experience the same problem in 1.6.x?
olesen is offline   Reply With Quote
Old   May 18, 2010, 14:23
David Gaden
That's the problem! Thanks Mark. I tried it in 1.6 and it works fine. So when I'm using 1.5-dev I'll just misalign the plane ever so slightly.
-Dave
Understanding the coordinates of sample utility vishwa OpenFOAM Post-Processing 4 March 25, 2010 13:51
sample MAPLE code for SIMPLE algorithm mia Main CFD Forum 0 February 28, 2009 00:22
heat conducting in a solid domain Rogerio Fernandes Brito CFX 0 March 18, 2008 18:20
about my old post Rogerio Fernandes Brito CFX 1 February 8, 2008 20:19
Looking for a simple way to mesh my sample Winnie FLUENT 5 July 29, 2005 06:32
