December 17, 2009, 09:39 |
Foam to Tecplot360
varun
Rep Power: 17 |
Is it possible to convert openfoam v1.5 results to tecplot360? if not, I would like to convert my results to fluent. But, where can i find the fluent unit numbers for fields like 'density' turbulence parameters 'omega' which have to be specified in the foamDataToFluentDict? I looked through the userguide but, only unit numbers available are for pressure, velocity, temperature, k and gamma. As always thnX 4 ur help foamer's!!! varun |
December 21, 2009, 11:35 |
Julien Schaguene
Rep Power: 17 |
just make a quick search and you will find this:
http://www.cfd-online.com/Forums/ope...available.html it's the first result for the search foam+tecplot. Is it so difficult? |
foamdatatofluent, postprocessing, tecplot |
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 05:20 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
