Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
basic question about the pressure
Old   December 1, 2009, 09:18
Question basic question about the pressure
AirS is on a distinguished road
Hi all,
This is very basic I think but I'd like to be sure about this:
In the pressure file 0/p, we set the dimensions of the pressure such as we need to multiply the pressure by the fluid density to get "Pascal" as units.
So, during the post-process, when we visualize the pressure, basically we need to multiply it by the fluid density to get the "real" pressure field.
Am I right?
Thanks.
AirS is offline   Reply With Quote
Old   December 2, 2009, 06:19
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
Yes you are correct: [p]=m^2/s^2; P=p*rho -> [P]=kg/(ms^2)=Pa
Regards,
Jose Santos
santos is offline   Reply With Quote
Old   December 2, 2009, 06:46
Thanks Jose.
Old   July 29, 2010, 12:02
Fernando
fsalvucci is on a distinguished road
So, another question related. What about "nu" units?
Im running a very simple case, flow through a pipe, imposing p = 0.026 at inlet and 0 at outlet. (p dimensions are [0 2 -2 0 0 0 0], that is p is divided by rho).
In transportProperties i set:
nu nu [0 2 -1 0 0 0 0] 3.047e-6;
Since the fluid im trying to simulate has a dinamic viscosity etha= 0.0032 Pa*s and densisty rho=1050 kg/m3. What i did was nu = 0.0032/1050 = 3.047e-6.
When i try to compare results with analytical solution, Poiseuille´s flow, vmax (of the parabola developed) should be:
vmax=(0.026 * r^2)/(4*L*nu)
But vmax in the results is around half the expected. Should there be a mistake considering nu units? Which are the units of 3.047e-6?
fsalvucci is offline   Reply With Quote
Old   July 29, 2010, 12:25
santos's Avatar
Jose Luis Santos
Fernando,
[0 2 -1 0 0 0 0]
declares the nu dimensions as m^2 s^-1.
I would say that your problem lies somewhere else, probably in the boundary conditions.
Regards,
Jose Santos
Old   July 29, 2010, 13:07
Fernando
Jose, thanks for the reply. Lets see, the mesh consists of a pipe, with an inlet, the wall, and the outlet. The boundary conditios are:
0/p:
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
wall
type zeroGradient;
inlet
type fixedValue;
value uniform 0.026;
outlet
type fixedValue;
value uniform 0;
0/U:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
pared
type fixedValue;
value uniform (0 0 0);
entrada
type zeroGradient;
salida
type zeroGradient;
I cannot find an error. I attach the velocity profile at the outlet, it seems preetty parabolic, but the analitical solution predicts a parabolic profile with maximmum velocity of 0.47 m/s.
Any idea? Im using simpleFoam, laminar, nu = 3.047e-6.
Thanks
Fluent natural ventilation pressure boundary condition pierresandre FLUENT 24 November 8, 2011 15:32
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 12:35
WENO - Basic Question Graham Main CFD Forum 4 October 31, 2006 18:52
Pressure correction question - Please help! Barry Main CFD Forum 1 February 5, 2003 01:27
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
