Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Mean Age of Air
Like Tree24Likes
Old   July 20, 2012, 17:20
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
same solutions with simple and pimple.
Attachements
Tobi is offline   Reply With Quote
Old   July 23, 2012, 06:55
Tibor Nyers
Toorop is on a distinguished road
unfortunately I have mixed up the correct solver with an old one with errors. A thunder storm killed the hard disk with the new, correct version and I posted my obsolete one - always back up, and correct old stuff as well ...
So the correct scalar equation with sources:
tmp<fvScalarMatrix> TEqn
        fvm::ddt(T) + fvm::div(phi, T) - fvm::laplacian(DTEff, T) == sources(T)
One have to add one more line to the solver:
sources.constrain(TEqn());
This function can be applied to set values in given cells - it has no effect on our setup, though, I added it for completeness.
Add sourcesProperties folder to your constant folder with entries:
age
    type            scalarExplicitSource;
    active          on;
    timeStart       0.0;
    duration        1.0;
    selectionMode   all;
    scalarExplicitSourceCoeffs
        volumeMode        specific;
        injectionRate
            T            1;
So the solver updates the T field, the value of time step is given to every cell. Check the release notes about field sources to get more information about this feature.
I double-checked this solution, and it gives the exact values of the solver that Andrew King has attached a while back. Andrew, thanks for your solution, quite useful!
About the term in the laplacian, I "borrowed" the idea from Daniel C, here's what he said about the issue. I set DT to zero since I don't want additional diffusion.
I don't know if this method can be used in a steady-state case since there's no explicit time stepping. But if the solution matches the transient version more or less than it can be valid.
WARNING: I don't validated any result to real world tests. Feel free to correct the solver, add your thoughts, thank you!
About your question:
if the flow is laminar, incompressible and you now the inlet properties (velocity / flow rate), I think it's just some basic calculations and it depends on the geometry of the diffusor. When the flow is turbulent I don't know how to calculate it, maybe there's some good approximations out there.
Tobi likes this.
Toorop is offline   Reply With Quote
Old   April 23, 2013, 14:07
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi
also it seems a dead thread.but I hope not and propound my question!
I have a inflow patch and need a lot to know if the inflowing fluid has reached to outflow patch or not.
preferably by rhoPimpleFoam.
both the fluid that rest in the channel at first(internalField) and the fluid is entering are the same (air) but entering air has more pressure and temperature.
is it possible to track entering air particles through the unsteady case I have?
to give more information if is important to answer the case is a rectangular tube with one inflow and one outflow patch.
how to modify the files in this thread in my case?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   April 23, 2013, 14:36
Tobi's Avatar
Tobias Holzmann
Originally Posted by immortality View Post
Hi
you can use implement a conserved scalar transport equation for that!
At the beginning your scalar is 1 at the inlet and the rest is zero.
While simulating your scalar is transported through the domain. In your case you should only use the transport due to convection and so you can have a look when the scalar reaches the outlet!
Hope its helpful.
Tobi
immortality likes this.
Old   April 23, 2013, 14:44
Ehsan
Hi Tobias
thanks for rapid reply!
I haven't modified a solver to solve for a new equation.
then could you please guide me.
I've added this in createFields:
volScalarField age
        IOobject
            "age",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        mesh
is this the only change should I do in createFiels.H or some other lines?
in the folder of solver I have to add this:
// --- Scalar Transport
	volScalarField DTEff = DT+turbulence->muEff()/0.7;
	tmp<fvScalarMatrix> AgeEqn
	 fvm::ddt(rho,Age) + fvm::div(phi, Age)   == dimensionedScalar("AgeSource", Age.dimensions()*dimensionSet(1,-3,-1,0,0), 1) //- fvm::laplacian(DTEff, Age)
	AgeEqn().relax();
	sources.constrain(AgeEqn());
	AgeEqn().solve();
I changed all T's to Age.and as you said to me should delete the laplacian term also,correct?
and what should be assign for DT?and also change nut to mut(since my case is compressible,unsteady) correct?
(does it work if I switch to a turbulent case too?)
Old   April 23, 2013, 17:40
Tobi's Avatar
Tobias Holzmann
have a look at my solver: https://github.com/shor-ty/scalarRhoSimpleFoam
Then use the scalarEqn.H and the entry in the createFields.H for your own pimple solver!
If there are any problems ask me!
Have a nice evening,
Tobi
Old   April 24, 2013, 08:23
Ehsan
thanks.
1)I can't download.this error occurs:
https://github.com/shor-ty/scalarRhoSimpleFoam.git
bash: https://github.com/shor-ty/scalarRhoSimpleFoam.git: No such file or directory
2)and also why ddt isn't there in equation?
    // --- Scalar transport
    tmp<fvScalarMatrix> SEqn
            fvm::div(phi, S)
          - fvm::Sp(fvc::div(phi), S)
              - fvm::laplacian(turbulence->muEff(), S)
    SEqn().relax();
    SEqn().solve(mesh.solver("S"));
3)how should I modify it to my unsteady compressible problem you know?
should I delete laplacian term totally?why you have not done this to delete laplacian term?then how can account for
turbulence?
4)what does this term is added?what does do?
Old   April 24, 2013, 14:47
Ehsan
hi
could you please help me with questions?
Old   April 24, 2013, 15:22
Tobi's Avatar
Tobias Holzmann
hi
i was at work till now.
1. on my computer the github link is working!
2. you have to set ddt into that equation; in my case I used the SIMPLE algo (steady-state; ddt = 0)
3. let the diffusion term in your case
4. thats a numerical trick for stabilisation
Old   April 24, 2013, 15:26
Tobi's Avatar
Tobias Holzmann
git clone https://github.com/shor-ty/scalarRhoSimpleFoam.git
Old   April 24, 2013, 18:30
Ehsan
thanks.then can you please give me a more description (or there is a source and internet link for that) about the term you has added for more stability.because may it be necessary to give some description in my thesis about each of terms in equations.
Old   April 25, 2013, 01:42
Tobi's Avatar
Tobias Holzmann
I wrote a PDF and posted it here ... but no time for searching at the moment.
Old   April 25, 2013, 03:01
Ehsan
ok.thank you.that would be nice.then i wait untill you come back.
and what does that expression argument in parenthesis in solve() function mean?is that for cases we have moving mesh?
Old   April 25, 2013, 08:43
Ehsan
and also in rhoPimpleFoam solver below is the position of gasEquation.H suitable(several times it solves) or it is better to be after pimple.loop() to solve one time each time step?
int main(int argc, char *argv[])
    #include "setRootCase.H"
    #include "createTime.H"
    #include "createMesh.H"
    pimpleControl pimple(mesh);
    #include "createFields.H"
    #include "createFvOptions.H"
    #include "initContinuityErrs.H"
    Info<< "\nStarting time loop\n" << endl;
    while (runTime.run())
        #include "readTimeControls.H"
        #include "compressibleCourantNo.H"
        #include "setDeltaT.H"
        runTime++;
        Info<< "Time = " << runTime.timeName() << nl << endl;
        if (pimple.nCorrPIMPLE() <= 1)
            #include "rhoEqn.H"
        // --- Pressure-velocity PIMPLE corrector loop
        while (pimple.loop())
            #include "UEqn.H"
            #include "EEqn.H"
            // --- Pressure corrector loop
            while (pimple.correct())
                #include "pEqn.H"
            if (pimple.turbCorr())
                turbulence->correct();
              #include "gasEqn.H"
        //Cp.write();
        runTime.write();
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
    Info<< "End\n" << endl;
    return 0;
thanks.
Old   April 25, 2013, 11:12
Ehsan
hello again
excuse me for questions.
I run the case but gas(scalar value) is not between 0 and 1 as the snapshot.
how to resolve?
thanks.
Old   April 25, 2013, 12:17
Tobi's Avatar
Tobias Holzmann
hello again
how to resolve?
thanks.
i dont know what you mean with gas. Is that your new scalar?
http://www.cfd-online.com/Forums/ope...tml#post407482
Old   April 25, 2013, 12:57
Ehsan
yes.at last i put the name gas in return of S.because air flowing in has a higher pressure and temperature than air in domain.shouln't it be between 0 and 1
Old   April 25, 2013, 13:24
Tobi's Avatar
Tobias Holzmann
The value of your scalar depend on yuor BC settings!
Old   April 25, 2013, 13:32
Ehsan
i have set it 1 for inflow and 0 for initial condition as you told.
Maybe because my case is compressible a change should be done.
The dimension is zero[0 0 0 0 0 0].is it correct?
Old   April 25, 2013, 14:41
Tobi's Avatar
Tobias Holzmann
I am a bit confused couse the tutorial added in my git repo is not the one i build for that. Its the CO/H2/N2 mesh
well maybe I have time to resolve that mesh but first I reset my computer for Arch Linux
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
local age of air in starccm+ Mike23 Siemens 3 September 20, 2008 12:16
[Indoor Air Quality]How do I calcauate "Age of Air Young CFX 6 April 29, 2008 00:14
age of air teddy Siemens 3 February 9, 2007 10:41
Age of Air In Star-CD Ted Crilly Siemens 1 February 19, 2005 20:50
