April 7, 2011, 15:07 |
#21 |
Fabian Braennstroem
Rep Power: 19 |
me again... fyi: basically I just commented out the not needed points and faces... this worked quite good. Now, I would like actually write out the complete mesh information including a boundary, neighbour, owner files. Do you have a hint, how I can do this? Best REgards! FAbian |
November 18, 2011, 16:37 |
#22 |
G.Paulo
Rep Power: 15 |
Dear foamers
Sampling data from the cells close to a boundary or a wall might not be a trivial matter. That is why I am calling back this some two years old thread, which is closely related to my present question. My geometry is composed of some curved walls and I need to collect some data, like U and p, from the very first layer of cells near the wall. It seems pretty straightforward to do that with the "sample" utility, if I new the coordinates of each cell centre, by just listing them under the type "cloud" in the sampleDict file. But this is where things go awry. So, is there an easy way to get the coordinates of some specific cells, in particular those bordering a wall? I would guess that cellSet might be an answer, but I could not find something like a source "boundaryToCell" in the topoSetDict. Or, alternatively, can anyone devise another approach to pick these close-to-the-wall cells values of velocity and pressure? BTW, this is almost exactly the question posed by Alejandro, above, but his problem was solved in a different way, so the the question remains alive. I would appreciate any suggestion on that. I am using OpenFOAM 2.0.0. Regards. G.Oliveira |
November 6, 2020, 00:19 |
arcUniform sampling utility
#23 |
Prakriti
Rep Power: 8 |
Hi all,
Has anyone tried using the arcUniform utility for postProcessing (https://cpp.openfoam.org/v6/classFoa...Uniform.html)? When I try to implement it, it just gives me an error saying "keyword endAngle is undefined in dictionary "controlDict.functions.sample.sample.sets"" I was wondering why it would do that? |
November 6, 2020, 02:52 |
#24 |
Rep Power: 9 |
You need to define endAngel. Or is the problem that you defined it but OpenFOAM is still complaining?
December 23, 2021, 09:57 |
#25 | |
Nishant
Rep Power: 15 |
You mentioned this in another reply as a solution(?): Can you please explain where exactly this change is made? |
November 7, 2024, 12:12 |
#26 |
Hi folks!
the new syntax is: Code:
<surfaceName> { type patch; patches (<patche_names>); // Export interpolated point-based data interpolate true; }
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at |
sample |
Importing or Creating 2D Flat Surfaces into CFX | Sam | CFX | 5 | March 30, 2013 12:11 |
creating new surfaces | fluentguy | FLUENT | 1 | May 7, 2009 04:34 |
Faceted surfaces in ICEM | Chriss | Main CFD Forum | 1 | May 6, 2008 16:18 |
Surfaces lost from ICEM to CFX-Pre 5.7 | Mark | CFX | 6 | October 1, 2004 00:07 |
Surfaces | Mark | FLUENT | 2 | February 9, 2004 11:41 |
