Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
FoamTOVTK
Old   July 6, 2009, 17:08
Default FoamTOVTK
Ramesh Yapalparvi
yapalparvi is on a distinguished road
I am new to using OpenFOAM. I have installed openfoam on a 32 bit machine running ubuntu 9.04. I could not get paraFOAM working so decided to use foamTOVTK and installed paraview. I ran the test case icoFOAM/cavity and got files in directories 0, 01, 02..05
I then used foamTOVTK and it created a folder called VTK. I then opened paraview and in open file clicked on cavity_vtk files. I tried the visulaise but nothing seems to appear on the screen. Could you please let me know the solution or if somebody has used the same thing please do let me know the step by step procedure. Thanks
Ramesh
yapalparvi is offline   Reply With Quote
Old   July 30, 2009, 19:18
Alan Harrland
Alan is on a distinguished road
Did you click on the root VTK file in the VTK folder? Then have you checked apply on the display properties?
If you update to foam-1.6 you wont have to worry about converting to VTK.
Alan is offline   Reply With Quote
Old   August 10, 2009, 09:14
Default multiRegionHeater
Alexander K.
Mercato is on a distinguished road
Good afternoon, I had installed OF 1.6 with ParaView 3.6.1. I meet problem with solver chtMultiregionFoam, test multiRegionHeater. ./Allrun was used and 200 sec calculations is OK. In paraFoam I can see results (K, epsilon, P, U e.t.c) only for zero time. How can I see all solution for other times?
Thanks advance.
Alex
Mercato is offline   Reply With Quote
Old   August 12, 2009, 09:19
Default answer
Alexander K.
Hello everybody.
It works with:
cd ~/OpenFOAM/user-1.6/run/heatTransfer/chtMultiRegionFoam/multiRegionHeater
paraFoam -region bottomAir
or
paraFoam -case multiRegionHeater -region bottomAir
instead of bottomAir you can use also region names:
heater, leftSolid, rightSolid, topAir
Best regards
Alex
[OpenFOAM] Too many time folders crash foamToVTK johndeas ParaView 4 September 25, 2008 16:07
FoamToVTK surfaceFields generates invalid files for 2D case 7islands OpenFOAM Bugs 3 September 2, 2008 10:04
[Technical] How to get polyhedral mesh without additional cells when using foamToVTK chnrdu OpenFOAM Meshing & Mesh Conversion 4 June 10, 2008 14:08
[OpenFOAM] FoamToVTK Animation with Paraview 3 podallaire ParaView 5 October 9, 2007 08:26
[OpenFOAM] FoamToVTK error with OF 13 melanie ParaView 1 May 22, 2006 05:40
