Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
bash script for pseudo-parallel usage of reconstructPar
Like Tree58Likes
Old   July 14, 2023, 04:07
TWB
quarkz is on a distinguished road
I am having problems when I specify the start and end times:
./parReconstructPar.sh -n 32 -t 0.07342,2.00042
      K. Wardle 6/22/09, modified by H. Stadler Dec. 2013, modified by G.Salvador-Vieira 6/8/18
      bash script to run reconstructPar in pseudo-parallel mode
      by breaking time directories into multiple ranges
running reconstructPar in pseudo-parallel mode on 32 processors
(standard_in) 1: syntax error
./parReconstructPar2.sh: line 93: [: ==: unary operator expected
./parReconstructPar2.sh: line 103: [: ==: unary operator expected
Can someone help?
quarkz is offline   Reply With Quote
Old   August 23, 2023, 03:48
Matej Tomić
MTomić is on a distinguished road
Originally Posted by quarkz View Post
Can someone help?
I am probably late to the party, but have you tried invoking the command with
sh ./parReconstructPar.sh -n 32 -t 0.07342,2.00042
Regards,
Matej
MTomić is offline   Reply With Quote
Old   May 8, 2024, 00:17
TWB
Hi MTomić, I just tried it on another case and it's working, although there's a minor error.
./parReconstructPar3.sh -n 64 -t 0.1,0.4
running reconstructPar in pseudo-parallel mode on 64 processors
reconstructing 3 time directories
making temp dir
Starting Job 1 - reconstructing time = 0.1 through 0.1
Job started with PID 3221222
Starting Job 2 - reconstructing time = 0.2 through 0.2
Job started with PID 3221234
Starting Job 3 - reconstructing time = 0.3 through 0.3
Job started with PID 3221288
3 directories remaining...
1 directories remaining...
finished
So t = 0.4 is not included. Did I do something wrong?
Thanks!
parallel processing, reconstructpar
Running decomposePar / reconstructPar as parallel apps? carcass OpenFOAM Running, Solving & CFD 3 January 17, 2024 08:19
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 23:51
Core usage on CFX parallel processing alterego CFX 6 December 21, 2011 06:45
Swap usage on parallel run nikhilesh OpenFOAM Running, Solving & CFD 0 April 30, 2009 10:50
TASCflow,problem with script and parallel mode Zbynek Hrncir CFX 0 October 2, 2001 08:30
