Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Problem with npoints in Sampling
Old   April 23, 2009, 06:07
Default Problem with npoints in Sampling
Prapanch Nair
prapanj is on a distinguished road
I want a line plot of out a 3d domain along a probe line. In my sampleDict, when I set npoints to 20 for a particular line, everything is fine. But if I change this number to increase the resolution, it doesn't work ( I mean when I run sample, it just says create mesh for time = 0 and hangs in there forever).
My grid definitely has more than 20 points. I had tried setting npoints to 19,21, 30,35, 40, 100 etc points. The same issue.
Now, there is another line in the domain for which I could set to other numbers and it works.
I have made sure I don't make any syntax error in setting npoints. What could possibly be wrong?
Thank you
Prapanj
prapanj is offline   Reply With Quote
Old   April 24, 2009, 17:21
M. Mahdi Salehi
smehdi609 is on a distinguished road
http://www.cfd-online.com/Forums/ope...-problems.html
smehdi609 is offline   Reply With Quote
hangs, npoints, probe, sample
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 11:33
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
convergence problem Trushar Phoenics 5 August 28, 2002 00:40
