March 12, 2005, 04:28 |
I need to plot the velocity an
Pratap Sathiah
Rep Power: 17 |
I need to plot the velocity and k, epsilon at a particular point in a domain.
What is the name of the utility for this. I know "sample" is used along line. Pratap |
March 12, 2005, 05:01 |
You can use sample along a lin
Mattijs Janssens
Rep Power: 26 |
You can use sample along a line (i.e. 'uniform' sampleSet type) with only one point (if that works - never tested it ;-) or use the 'cloud' sampleSet type.
See http://www.opencfd.co.uk/openfoam/doc/userse31.html Cloud takes a 'points' entry in its dictionary instead of 'start' and 'end'. Just look at the error messages if you get it wrong and you should be able to work out the syntax. Mattijs (does anyone have some time to spare to put all the sample options into FoamX? It now seems to do only part of it) |
January 11, 2007, 10:58 |
HI,
I will write in the a fil
HI,
I will write in the a file a filed in a fixe position vs time. How can I do this ? I tried to modifie sample.C but when I write the new value of filed with the current time it delete the old one . thanks a lot |
Sampling Reynolds stress | antonio_ing | OpenFOAM Running, Solving & CFD | 0 | February 27, 2009 06:59 |
Help! Sampling! | HP | FLUENT | 0 | May 15, 2008 10:29 |
sampling theorem and cfd | luis | Main CFD Forum | 0 | December 17, 2006 23:06 |
Sampling of statistical data | Boerge | Main CFD Forum | 0 | July 25, 2006 04:40 |
Sampling on a patch | liu | OpenFOAM Running, Solving & CFD | 3 | May 25, 2005 06:52 |
