January 16, 2008, 13:44 |
a pretty simple one... I
Fabian Braennstroem
Rep Power: 19 |
a pretty simple one... I hope... I would like to create a new postprocessing variable using: volScalarField test ( IOobject ( "test", runTime.timeName(), mesh, IOobject::NO_READ ), (fvc::grad(U))/mag(fvc::laplacian(U.component(i))) ); test.write(); This works fine as long as U.component(i) has some kind of value, but if the denominator is zero I get obviously an error. Can anyone give me an advice, how an 'if' question could look like? I tried somehting like: if (U.component(i)==0.0){...} but I get: test.C: In function 'int main(int, char**)': test.C:128: error: expected primary-expression before 'if' Fabian |
January 21, 2008, 12:08 |
me again... does nobody
Fabian Braennstroem
Rep Power: 19 |
me again... does nobody has an idea!? Regards! Fabian |
January 21, 2008, 12:41 |
General practice is to add a s
Eugene de Villiers
Rep Power: 21 |
General practice is to add a small constant to the denominator:
fvc::grad(U)/(smallU + mag(fvc::laplacian(U.component(i)) where smallU is something like: dimensionedScalar("smallU", dimensionSet(0,0,-1,0,0), SMALL); |
January 21, 2008, 13:07 |
Your "if" statement would not
Gavin Tabor
Rep Power: 17 |
Your "if" statement would not work because U.component(i) would never be identically equal to 0.0. Eugene is correct; the usual thing is to add a small value to the denominator. However you might also want to think about what the value of the numerator is when the denominator is zero. If the denominator is non-zero, then the expression is diverging at that point; you might want to think whether your modelling is correct at this point.
introducing smallU on the denominator will set this to an artificial (if quite large) number - is this what you want? On the other hand, if the denominator is also zero, you have 0/0 from the fraction. This is not zero; it is UNDEFINED. The fraction may in fact tend towards a non-zero value; you need to look at 1st and higher derivatives of the numerator/denominator to determine this. Again, using smallU will fix the value to zero, which may not be what you want in practice. Gavin |
January 21, 2008, 14:10 |
Hi Eugene,
thanks, good ide
Fabian Braennstroem
Rep Power: 19 |
Hi Eugene,
thanks, good idea! It works with a small adjustmentdimensionedScalar smallU ("smallU", dimensionSet(0,1,-1,0,0), SMALL); . Is there any recommendation where to put the smallU declaration? I put it on top of the .C file!? Regards! Fabian |
January 21, 2008, 15:14 |
Hi Gavin,
I was a bit to sl
Fabian Braennstroem
Rep Power: 19 |
Hi Gavin,
I was a bit to slow submitting the post... Thanks for your help. The SMALL number will actually work for my case, but is there a chance to use some kind of range for the if-condition in this 'template' (this is an template, isn't?)? Fabian |
January 22, 2008, 09:37 |
I normally put stuff like that
Eugene de Villiers
Rep Power: 21 |
I normally put stuff like that in "createFields.H", but it doesn't really matter.
January 24, 2008, 15:55 |
Thanks!
Fabian Braennstroem
Rep Power: 19 |
Thanks!
January 28, 2008, 11:02 |
Thanks!
#9 |
Fabian Braennstroem
Rep Power: 19 |
Thanks!
RP_Set_Real("variable-name", variable name) | bohis | FLUENT | 1 | March 9, 2009 08:44 |
Post, Calculate Variable in plane | Kordou | CFX | 1 | October 14, 2008 17:39 |
hi how to calculate the HTC | kathir | Siemens | 0 | March 26, 2006 10:31 |
how to calculate y+ in cfx? | micaheal | CFX | 3 | November 21, 2005 15:45 |
how to calculate CL and CD | zhaoyu | FLUENT | 1 | April 24, 2001 10:56 |
