April 27, 2017, 17:52 |
#61 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
mixingEff1 { type swakExpression; verbose true; valueType faceZone; zoneName control1; expression "alpha*YH2*phi*flip()/inflowH2"; accumulations ( sum ); variables ( "inflowH2{inlet}=sum(phi*YH2);" "alpha=equivRatio<1 ? 1 : 1/equivRatio;" ); }
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
April 28, 2017, 05:39 |
#62 | |
Mukesh Adlak
Rep Power: 10 |
Thanks gschaider, Should I put this expression in controldict file and will it work in openfoam-3.0.x ??? I will study this and try to implement it. Thanks again for ur quick reply. |
May 1, 2017, 16:58 |
#63 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The solution would require swak4foam (you'll have to install that). The last release of that should work with OF 3.0. Yes. It goes into the functions-dictionary in the controlDict
May 12, 2017, 06:54 |
#64 | |
Mukesh Adlak
Rep Power: 10 |
Hi gschaider, I understood all but except following 3 things: verbose true; valueType faceZone; zoneName control1; Not sure but facezone might be related to cross section over I want to calc. efficiency. I dont have any facezones or facesets. If I will create facezones using toposet it will create patches for that but it may affect the flow field inside the domain. i dont know about the sampledsurfaces, will it be useful for my case ? |
January 9, 2020, 15:08 |
For MultiRegion
#65 |
Pratyush Kumar
Rep Power: 7 |
Hello Anne Gerdes,
How can I use this utility for Multi region case, running in parallel ? |
April 4, 2024, 11:47 |
#66 |
Rep Power: 3 |
Hi there,
I improved a bit the provided code that was originally OF-2. It works pretty neat now for OF-10. Please, enjoy. Use: calcMassFlow -latestTime (no other optional arguments accepted) If someone can 'repair' the time loop that I plugged in, thank you in advance... |
Calculate Mass Flow in a faceSet during calculation | torvic | OpenFOAM Running, Solving & CFD | 1 | August 11, 2008 19:05 |
mass flow rate calculation | Ahmed | CFX | 7 | June 20, 2008 05:55 |
Calculation of mass flow rate | msrinath80 | OpenFOAM Running, Solving & CFD | 0 | April 18, 2007 14:05 |
Calculation of added mass in viscous flow | kharati | Main CFD Forum | 2 | February 1, 2006 00:28 |
Mass Flow Rate Calculation | Paul | FLUENT | 9 | March 23, 2002 08:37 |
