Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
FvPatch operations
Old   July 9, 2008, 08:14
Default cell face side length. I ne
Maka Mohu
maka is on a distinguished road
I need to access the length of cell face in x or z direction. The cells are have hexagonal shape. I thought to use sqrt(magSf) but this will be correction only if dx=dz. Do you know any way to do this. Thansk.
Best regards,
Maka.
maka is offline   Reply With Quote
Old   July 9, 2008, 08:39
Default I thought of the following but
Maka Mohu
I thought of the following but it is only valid if mesh resolution in z direction (dz) is uniform.
const fvPatchScalarField& vsfp = vsf.boundaryField()[patchI];
// first cell
scalar cf1 = vsfp[xPatchFaceLabel(0,k)].patch().Cf();
scalar A1 = vsfp[xPatchFaceLabel(0,k)].patch().magSf();
// last cell
scalar cfn = vsfp[xPatchFaceLabel(nx()-1,k)].patch().Cf();
scalar An = vsfp[xPatchFaceLabel(nx()-1,k)].patch().magSf();
// Assuming constant resolution in z direction and cell centered node.
scalar dz = (A1+An)/(2*(cf1+cfn));
scalar dx1 = A1/dz;
scalar dxn = A2/dz;
is there a general solution, like using bounding box on the cell? Thanks.
Old   July 9, 2008, 08:40
Default scalar dxn = An/dz; That was a
Maka Mohu
scalar dxn = An/dz; That was a correction.
Old   July 9, 2008, 12:37
Default The above is wrong, the correc
Maka Mohu
The above is wrong, the correct way is to get: faces from the patch and get the edges. I can do that but the problem is that I can not find the function that gives the faceList from polyPatch for example
vsfp.patch().*?* will give faceList of the patch ?
Old   July 10, 2008, 08:36
Default The solution is: vsfp.patch()
Maka Mohu
The solution is:
vsfp.patch().patch().localFaces()[face_label].edges()[edge_label].centre(vsfp.pa tch().patch().localPoints())
Nonbasic mathematical operations ngj OpenFOAM 0 September 26, 2008 18:16
Nonparallelized operations in OpenFOAM adona058 OpenFOAM Running, Solving & CFD 0 September 20, 2007 16:57
Cleaning up operations Vidya Raja FLUENT 3 May 22, 2006 15:17
body operations fintan CFX 3 December 1, 2005 00:05
GET_GVAR operations? Cujo CFX 3 July 23, 2003 12:27
