Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
FoamToVTK and MayaVi
Old   July 30, 2008, 09:20
Default i tried adding liftDrag utilit
  #41
mayank gupta
mgz1985 is on a distinguished road
i tried adding liftDrag utility box as mentioned in the download link but i m getting the following error.
as i m new to linux can u type me the xact commands
Making dependency list for source file liftDrag/liftDrag.C
could not open file incompressible/turbulenceModel/turbulenceModel.H for source file liftDrag/liftDrag.C
could not open file incompressible/LESmodel/LESmodel.H for source file liftDrag/liftDrag.C
SOURCE=liftDrag/liftDrag.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/transportModels -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/turbulenceModels -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/LESmodels -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/LESmodels/LESdeltas/lnInclude -IlnInclude -I. -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/liftDrag.o
/home/frpelikan/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../libexec/g cc/x86_64-unknown-linux-gnu/4.3.1/cc1plus: error while loading shared libraries: libmpfr.so.1: cannot open shared object file: No such file or directory
make: *** [Make/linux64GccDPOpt/liftDrag.o] Error 1
Making dependency list for source file cLiftDrag/cLiftDrag.C
could not open file compressible/turbulenceModel/turbulenceModel.H for source file cLiftDrag/cLiftDrag.C
could not open file compressible/LESmodel/LESmodel.H for source file cLiftDrag/cLiftDrag.C
SOURCE=cLiftDrag/cLiftDrag.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/specie/lnInclud e -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/basic/lnInclude -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/turbulenceModels -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/LESmodels -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/LESmodels/LESdeltas/lnInclude -IlnInclude -I. -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/cLiftDrag.o
make: *** [Make/linux64GccDPOpt/cLiftDrag.o] Error 1
frpelikan@Techn-028:~/OpenFOAM/OpenFOAM-1.5/src/postProcessing$ cd ..
frpelikan@Techn-028:~/OpenFOAM/OpenFOAM-1.5/src$ cd ..
frpelikan@Techn-028:~/OpenFOAM/OpenFOAM-1.5$ cd applications/utilities
frpelikan@Techn-028:~/OpenFOAM/OpenFOAM-1.5/applications/utilities$ cd postProcessing/miscellaneous
frpelikan@Techn-028:~/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/miscellaneous$ wmake
wmake error
'Make' directory does not exist
frpelikan@Techn-028:~/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/miscellaneous$ ./Allwmake
bash: ./Allwmake: No such file or directory
frpelikan@Techn-028:~/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/miscellaneous$ cd liftDrag
frpelikan@Techn-028:~/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/miscellaneous/lif tDrag$ wmake
Making dependency list for source file liftDrag.C
could not open file incompressible/turbulenceModel/turbulenceModel.H for source file liftDrag.C
could not open file incompressible/LESmodel/LESmodel.H for source file liftDrag.C
could not open file compressible/turbulenceModel/turbulenceModel.H for source file liftDrag.C
could not open file compressible/LESmodel/LESmodel.H for source file liftDrag.C
SOURCE=liftDrag.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude/ -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/cfdTools/general/lnInclude -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/specie/lnInclud e -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/basic/lnInclude -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/turbulenceModels -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/transportModels -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/postProcessing -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/LESmodels -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/LESmodels/LESdeltas/lnInclude -IlnInclude -I. -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/frpelikan/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/liftDrag.o
frpelikan@Techn-028:~/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/miscellaneous/lif tDrag$ cd ~/
mgz1985 is offline   Reply With Quote
Old   July 30, 2008, 09:36
Default Hi Mayank, I do not know ye
  #42
Alexandre Pereira
alexandrepereira is on a distinguished road
Hi Mayank,
I do not know yet if liftDrag compiles in OF 1.5 w/o changing some dependencies...
If u r ok in c++ should be no problem, anyway, always used it in OF-1.4.1.
About blockMesh and blockMeshDict, i never really used it... i always build my meshes with external meshers, and export them with the mesh converting utilities...
But i take it the syntax guides in OF- Userguide show how to build a blockMeshDict file... don't them ? ...
Really dunno here... never had yr problem, because never used, ( or plan to use ...) blockMesh, i always work with "kimky" 3D stuff...
Regards
Alex
alexandrepereira is offline   Reply With Quote
Old   July 30, 2008, 09:42
Default Hi Again... Do u realy need
  #43
Alexandre Pereira
Hi Again...
Do u realy need liftDrag in OF-1.5...?
U can use this
http://www.cfd-online.com/cgi-bin/Op...cus/discus.cgi
I guess liftDrag is obsolete in OF-1.5...
Alex
Old   July 30, 2008, 10:02
Default yeah i need it as i have to ve
  #44
mayank gupta
yeah i need it as i have to verify the drag and lift coefficients for an airfoil incompressible flow.
the link u sent above is pointing me to a forum
is there any other way of finding the coefficients.
Old   July 30, 2008, 11:43
Default hi i m decent in C++, so ho
  #45
mayank gupta
hi
i m decent in C++, so how do i calculate using my knwoledge of C++. Do i have to write a programme and recompile it. I am scared more of Linux.
regarding the blockMeshDict my syntax is correct for sure
besides SALOME what other softwares are available for 3d mesh in linux as openware
Old   July 30, 2008, 17:53
Default Hi U do not have to rewrite
  #46
Alexandre Pereira
Hi
U do not have to rewrite liftDrag, and i bet it takes a bit more than just plain C++ knowlege to build a post processing CFD tool like liftDrag... :-)
just update your dependency lists, as wmake spotted it... dependencies are incorrect...
As to meshing, you have gmsh, NetGen, TetGen as openware,
For commercial software, you have Harpoon, ICEM-CFD, Gambit, Pointwise, and GridGen.
Alex
Old   July 31, 2008, 06:42
Default hi all, Please can sum1 run
  #47
mayank gupta
hi all,
Please can sum1 run this mesh and tell me why do the edges 1 2 and 7 8 not coincide.
it is because of this, i m getting a failed mesh in skewness.
I have checked my vertices and points in polyLine all of them should co-incide according to my input.
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.5 |
| \ / A nd | Web: http://www.OpenFOAM.org |
| \/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 0.001;
vertices
(181 -27.39 0)
(209.26 61.17 0)
(600 0 0)
(600 500 0)
(209.26 500 0)
(181 -500 0)
(181 -27.39 1)
(209.26 61.17 1)
(600 0 1)
(600 500 1)
(209.26 500 1)
(181 -500 1)
blocks
hex (0 1 4 5 6 7 10 11) (40 1 1) simpleGrading (4 1 1)
hex (1 2 3 4 7 8 9 10) (15 1 1) simpleGrading (1 1 1)
edges
polyLine 0 1 (
(151.99 -26.69 0)
(122.49 -25.57 0)
(92.87 -23.67 0)
(63.09 -20.64 0)
(48.1 -18.59 0)
(32.99 -15.91 0)
(17.63 -11.97 0)
(9.72 -8.96 0)
(6.43 -7.24 0)
(4.73 -6.13 0)
(0 0 0)
(1.27 7.88 0)
(2.56 9.7 0)
(5.28 12.72 0)
(12.37 18.52 0)
(27.01 27.09 0)
(41.9 33.62 0)
(56.91 39 0)
(87.13 47.45 0)
(117.51 53.7 0)
(148 58.21 0)
(178.58 61.17 0)
polyLine 6 7(
(151.99 -26.69 1)
(122.49 -25.57 1)
(92.87 -23.67 1)
(63.09 -20.64 1)
(48.1 -18.59 1)
(32.99 -15.91 1)
(17.63 -11.97 1)
(9.72 -8.96 1)
(6.43 -7.24 1)
(4.73 -6.13 1)
(0 0 1)
(1.27 7.88 1)
(2.56 9.7 1)
(5.28 12.72 1)
(12.37 18.52 1)
(27.01 27.09 1)
(41.9 33.62 1)
(56.91 39 1)
(87.13 47.45 1)
(117.51 53.7 1)
(148 58.21 1)
(178.58 61.17 1)
polyLine 1 2 (
(270.92 60.74 0)
(301.38 57.75 0)
(331.64 53.76 0)
(361.75 48.94 0)
(391.73 43.47 0)
(421.6 37.5 0)
(451.39 31.24 0)
(472 26.86 0)
(481.13 24.92 0)
(510.84 18.6 0)
(516 17.34 0)
(520.2 16.62 0)
(540.56 12.32 0)
(570.25 6.15 0)
polyLine 8 9 (
(270.92 60.74 1)
(301.38 57.75 1)
(331.64 53.76 1)
(361.75 48.94 1)
(391.73 43.47 1)
(421.6 37.5 1)
(451.39 31.24 1)
(472 26.86 1)
(481.13 24.92 1)
(510.84 18.6 1)
(516 17.34 1)
(520.2 16.62 1)
(540.56 12.32 1)
(570.25 6.15 1)
polyLine 4 5 ((-100 400 0) (-100 -400 0))
polyLine 10 11 ((-100 400 1) (-100 -400 1))
patches
wall fixedWalls
(0 5 4 1)
(0 1 7 6)
(0 5 11 6)
(5 11 10 4)
(6 7 10 11)
(1 2 3 4)
(1 7 8 2)
(2 3 9 8)
(3 4 10 9)
(7 8 9 10)
mergePatchPairs
Thanx
Old   July 31, 2008, 06:44
Default yeah even after changing the e
  #48
mayank gupta
yeah even after changing the edge to 7 8 in polyLine. i still get the error of skewness.
can sum1 help
Old   August 5, 2008, 06:24
Default hi all, i tried converting da
  #49
davey david
suredross is on a distinguished road
hi all,
i tried converting data to Fieldview for my case and came up with this error message:
| \ / O peration | Version: 1.4.1 |
| \ / A nd | Web: http://www.openfoam.org |
Exec : foamToFieldview9 OpenFOAM/OpenFOAM-1.4.1/tutorials/junctionFoam/ rectCyo
Date : Aug 05 2008
Time : 11:18:50
Host : sm-pc16-linux.bcinet-uni-dortmund.de
PID : 11008
Root : OpenFOAM/OpenFOAM-1.4.1/tutorials/junctionFoam/
Case : rectCyo
Nprocs : 1
Create time
Create mesh for time = 0
fileName::stripInvalid() called for string physicalProperties~
Aborted
[cfd@sm-pc16-linux ~]$
anybody with an idea what the problem is?by the way the command runs on other cases of mine.
suredross is offline   Reply With Quote
Old   August 5, 2008, 09:36
Default Try renaming "physicalProperti
  #50
Takuya OSHIMA
7islands is on a distinguished road
Try renaming "physicalProperties~" in your case directory to a name which contains only alphabets or numbers, or simply removing it.
By the way this is one of the major pitfalls my students fell into while I was teaching OpenFOAM in my course.
Takuya
7islands is offline   Reply With Quote
Old   August 5, 2008, 10:55
Default hi Takuya, thanks for the hel
  #51
davey david
hi Takuya,
thanks for the help.the problem is i have no such file in my case directory,so i am really confused by that message.do you or anyone have any other ideas??
thanks once again
Old   August 5, 2008, 11:23
Default Ah since foamToFieldView9 is c
  #52
Takuya OSHIMA
Ah since foamToFieldView9 is crashing after displaying "time = 0" it's likely in the 0 subdirectory, probably with a whitespace in its filename.
T
Old   August 5, 2008, 12:01
Default well,i have checked the 0 subd
  #53
davey david
well,i have checked the 0 subdirectory and there is no such file in there.i don't know what is amiss really.any more ideas?thanks
Old   August 5, 2008, 12:04
Default here is the 0 subdirectory,i c
  #54
davey david
here is the 0 subdirectory,i cant seem to find the problem:
/attach{0}
Old   August 5, 2008, 12:05
Default sorry.here we go http://www.
  #55
davey david
sorry.here we go
0.tar.gz
Old   August 5, 2008, 12:13
Default So... 1. What is the output o
  #56
Takuya OSHIMA
So...
1. What is the output of "find ." in the case directory?
2. What will happen if you turn off DebugSwitches of word and fileName (open ~/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/controlDict and modifiy the default debug levels of 2 to 0)?
T
Old   August 6, 2008, 06:03
Default when i run the find command,no
  #57
davey david
when i run the find command,no such file is seen.with your second suggestion ,i am a bit lost.could you explain further?thank you.
Old   August 11, 2008, 05:15
Default hi Takuya, i have seen the pr
  #58
davey david
hi Takuya,
i have seen the problem.it was a hidden file in my constant folder-guess i was looking in the wrong place!
thanks for your help.
davey
Problem with channeloodles and foamToVTK farbfilm OpenFOAM Running, Solving & CFD 0 October 31, 2008 06:28
[OpenFOAM] FoamToVTK problem oevermann ParaView 6 July 11, 2006 16:10
[OpenFOAM] FoamToVTK error with OF 13 melanie ParaView 1 May 22, 2006 05:40
what is Mayavi and what is vtk ztdep Main CFD Forum 1 July 14, 2005 12:08
Mayavi A.S. Main CFD Forum 1 July 12, 2005 15:07
