January 26, 2009, 10:15 |
Hi all.
I'm trying to export
Flavio Pergolesi
Rep Power: 17 |
Hi all.
I'm trying to export some results from foam to fluent. I realized that something strange happens, because when I plot the velocity magnitude (in contour or vectors) fluent displays something similar to paraFoam, but if I plot velocity components it displays a 0 value field, or strange results that don't even fit with the direction of the flow. As I found in a thread concerning this topic, I specified in foamToFluentDictionary not only the vector field U on entry number 2 but also the components Ux (entry 111), Uy (112), Uz (113). But I still can't import the data correctly in Fluent. Thanks in advance for any help you might feel like to give. Flavio |
November 9, 2009, 10:27 |
Hello
shuminhua
Rep Power: 17 |
I want to postprocess the openFOAM results in Fluent .When I use foamDataToFluent to change it , it generate *.dat files ,but I need *.dat and *.cas in fluent. What i should to do?
Thanks for all reply! |
velocity components at blade tip | Sridevi | CFX | 3 | April 30, 2022 12:55 |
What are the UVW velocity components | Nikunj | FLUENT | 2 | January 12, 2022 13:28 |
Obtaining velocity components | srinath | OpenFOAM Programming & Development | 16 | March 27, 2021 13:49 |
How to specify velocity components in UDF | Ynot | FLUENT | 1 | March 11, 2006 14:53 |
Velocity components visualization | Sileno | Phoenics | 1 | September 28, 2005 13:06 |
