It would be wonderful if a tool for FoamToTecplot is available |
January 29, 2009, 12:56 |
Hi Dennis,
I am also having
#81 |
Alexandre Pereira
Rep Power: 17 |
Hi Dennis,
I am also having some prob in porting foamToTecplot to OF-1.5.x... I take it something has to be changed in /Make/options, but what exactly...? I am not much familiarized with OF-1.5 yet.... Best regards Alex |
January 29, 2009, 13:07 |
I don;t have time to perform a
#82 |
Dennis Kingsley
Rep Power: 17 |
I don;t have time to perform a diff and tell you what changed so I have uploaded the code.
January 29, 2009, 17:26 |
Hi Dennis
Thanx a lot... bu
#83 |
Alexandre Pereira
Rep Power: 17 |
Hi Dennis
Thanx a lot... but I cannot get it from this page... The only thing that shows up is the pic of a folder... but the link doesn't work... :-( Alex |
January 29, 2009, 17:55 |
second try.
http://www.cfd
#84 |
Dennis Kingsley
Rep Power: 17 |
January 29, 2009, 18:28 |
Thx a Lot Dennis :-)
#85 |
Alexandre Pereira
Rep Power: 17 |
February 24, 2009, 00:10 |
why i got some file named *.un
#86 |
Jun Huang
Rep Power: 17 |
why i got some file named *.unk. how to open them?
February 24, 2009, 01:42 |
well, i opened the *.unk file
#87 |
Jun Huang
Rep Power: 17 |
well, i opened the *.unk file using tar -zxvf cmd. and put it at $HOME/OpenFOAM/OpenFOAM-1.1/applications/utilities/postProcessing/dataConversion /foamToTecplot/
using ls command ,shows root@jun-desktop:/home/jun/OpenFOAM/install/foamToTecplot# ls checkFoamData.H Make writeDXheader.H foamToTecplot.C writeDXdata.H writeDXseries.H foamToTecplot.dep writeDXgrid.H writeTECfile.H How to make it? my error is below: root@jun-desktop:/home/jun/OpenFOAM/install/foamToTecplot# wmake bash: wmake: command not found. How to install wmake? |
May 4, 2009, 07:49 |
mesh refinement and tecplot
#88 |
Giuseppina
Hi all,
I want to use foamtotecplot with a refined mesh. The code breaks up and It is not able to translate the data. The problem is in writeTECfile.H, I have modified the begining of the file as { const pointField& points = mesh.points(); const cellShapeList& cells = mesh.cellShapes(); num_cell = 0; forAll(cells, celli) { const labelList& shapeLabels = cells[celli]; const labelList& cll = mesh.cellPoints()[celli]; if(shapeLabels.size()>3) { num_cell = num_cell+1; } if(shapeLabels.size()<4) // 4 is the minimum number of points for the pyramid cell. { num_cell = num_cell+1; cout<<cll.size()<<"\n"; cout<<"number of points per cell"<<cll.size()<<"\n"; } } When a cell is a neighbour of refined cells, the numeber of points of each cell grows up. When the number of cellpoints is higher then 8, the cellShapes drops to 0. cellShapes is used to create the tecplot connection matrix as in the lines switch(shapeLabels.size()) { case 8: // hex dataOut << shapeLabels[0]+1 << tab << shapeLabels[1]+1 << tab << shapeLabels[2]+1 << tab << shapeLabels[3]+1 << tab << shapeLabels[4]+1 << tab << shapeLabels[5]+1 << tab << shapeLabels[6]+1 << tab << shapeLabels[7]+1 << endl; break; If we try to use directly cellPoints there, they are not ordered and the connection matrix of tecplot does not work well. Can you help us? thank you Giuseppina |
May 8, 2009, 04:31 |
cylcic B.C
#89 |
Ehsan
Rep Power: 17 |
Dear all,
My geometry includes cyclic boundary conditions and when I issue foamToTecplot, it gives me the error of "segmentation fault". What should I do in source files of foamToTecplot to recognize this B.C as well? Regards |
May 8, 2009, 13:50 |
Tecplot Users Unite
#90 |
Dennis Kingsley
Rep Power: 17 |
Everyone using Tecplot with OpenFoam should make some noise for a native OpenFOAM interface in Tecplot.
Tecplot representatives have recently taken notice and are trying to determine the number of users who would benifit. I do not work for Tecplot, but I have a fair number of licenses. djk |
May 8, 2009, 17:27 |
Tecplot user contact
#91 |
Scott Rumage
Rep Power: 17 |
As a follow on to Dennis' statement:
My name is Scott Rumage, and I am Tecplot's Partner & Code Interface manager. If you have any comments or suggestions on why and how Tecplot should enhance its relationship with OpenFOAM, then please let me know via this forum or at s dot rumage at tecplot dot com. I want to be very open about this -- I cannot make promises at this stage of how we will engage with the OpenFOAM community, but we are trying to understand what actions we can take that will give the greatest value to our users. Thanks ahead of time for your time and comments on this subject. |
May 10, 2009, 10:18 |
#92 |
Ehsan
Rep Power: 17 |
Dear Scott,
Please see: http://www.cfd-online.com/Forums/ope...available.html It is a 5 page forum about how to convert OF data to tecplots. It will be nice if tecplot had a loader for OF solutions. Regards |
June 3, 2009, 09:51 |
#93 |
Dr. Fabian Schlegel
Rep Power: 18 |
I use the foamToTecplot utility for data conversion between OpenFoam and Tecplot. First this is a great utitility but i miss something. I added the fieldAverage function to my controlDict and I get the Umean, Uprime2mean, pmean and pprime2mean values in my Openfoam time directory. If I now convert this time directory with foamToTecplot I only get the Umean, pmean and pprime2mean values in my Tecplot-file. But I need also the Uprime2mean values for calculating the reynolds stresses. I guess this field is not treated by the converter? I would be great if somebody could help and tell what I have to add to the source code of the converter for treating this fields too. thx fs82 |
June 3, 2009, 10:52 |
#94 |
Julian Krick
Rep Power: 17 |
Hallo,
I'm using OpenSuse 10.3. I tried to compile foamToTecplot and encountered the following error: Making dependency list for source file foamToTecplot.C SOURCE=foamToTecplot.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/julian/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/julian/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/julian/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/foamToTecplot.o /home/julian/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../libexec/gcc/x86_64-unknown-linux-gnu/4.3.1/cc1plus: error while loading shared libraries: libmpfr.so.1: cannot open shared object file: No such file or directory make: *** [Make/linux64GccDPOpt/foamToTecplot.o] Fehler 1 Here is the solution: - go to Yast and install the following packages: "mpfr" and "mpfr-devel" - then go again to the /foamToTecplot/ directory and type again: wmake It should compile correctly, then.
grid generation: ICEM CFD 13.0 solver: CFX 13.0 |
June 4, 2009, 12:31 |
#95 |
Dr. Fabian Schlegel
Rep Power: 18 |
Allright I found the solution of my problem. The converter indeed do not convert symmTensor fields, e.g. UPrime2Mean if you use the averaging function. But after a long search within the forum I found the solution. One have to use the utility <foamCalc components UPrimeToMean> and this splits the symmTensor into its parts xx,yy,zz,xy,xz,yz and writes 6 new scalar fields which could be converted by foamToTecplot.
June 5, 2009, 13:10 |
#96 |
xinguang cui
Rep Power: 17 |
Hey dkingsley:
It is very pity that I can not download the files. Would you like to send the file to my email? I will be grateful for your kind help. Ps: My openfoam version is 1.5. Thanks and best wishes! |
June 5, 2009, 13:16 |
#97 |
xinguang cui
Rep Power: 17 |
Hey foamers:
I hope all of you have a good mood everyday. The foamTotecplot is very great work. I would like to use the utility. It is very pity that I can not download the files from the netpage. Is anyone kind enough to send me the files to my email:loneboard@gmail.com? I will be grateful for your kind help. Ps: My openfoam version is 1.5. Thanks and best wishes! |
October 1, 2009, 07:06 |
#98 |
Jens
Hi, forget about this posting, I saw to late that there are news. I don't know how to delete it. Thanks!
Hi, is there news about foamToTecplot? Is there a new version available? Thanks for an answer! |
October 7, 2009, 06:38 |
#99 |
Steffen
Rep Power: 17 |
Hello Everybody,
I was just wondering, if there is a version of foamToTecplot (like "foamToTecplot1.5.x.tar.gz" from Dennis Kingsley) that works with openFOAM 1.6.? Thanks to the very helpful people here, I could manage to get foamToTecplot running on openFOAM 1.5, but I'm still struggling to get it running on openFOAM 1.6... Thanks for your help! Best regards, Steffen |
October 7, 2009, 23:55 |
#100 |
Huang
Rep Power: 17 |
I changed the following in foamToTecplot.C (1.5.x )so that it can run in 1.6.x.
// volPointInterpolation pInterp(mesh, pMesh); volPointInterpolation pInterp(mesh); |
Problem manipulating Data in Tecplot after foamToTecplot Conversion | titio | OpenFOAM Post-Processing | 2 | June 10, 2010 05:23 |
CFD science or tool? | Mateusz | Main CFD Forum | 10 | November 25, 2008 00:16 |
[mesh manipulation] ScalePoints tool | cedric_duprat | OpenFOAM Meshing & Mesh Conversion | 6 | September 19, 2008 04:15 |
Gridgeneration Tool | AndyR | Main CFD Forum | 2 | May 23, 2008 09:49 |
PDF repaire tool? | John | Main CFD Forum | 0 | February 23, 2008 08:32 |
