Sebastian Gatzka
Rep Power: 20 ![]() |
Hello World.
I'm struggling trought the second tutorial. I came to the point of comparing the numerical solution with the analytical. Unfortunately I don't get what to do with the plot command stated as: plot [0.5:2] '<datafile>', 1e4*(1+(0.125/(x**2))+(0.09375/(x**4))) What has to be in the place of <datafile>? As I have found there is no specific file created by the sample utility - rather there are some empty directorys. I have installed gnuplot with x11-package. What am I doing wrong?
Schrödingers wife: "What did you do to the cat? It's half dead!" |
Michael Jaworski
Rep Power: 17 ![]() |
Hello Sebastian,
Something is not correct if the utility is not creating a file. The file structure should look like this: <root>/<case>/samples/<timesteps>/<samplefiles> that is, it makes a "samples" subdirectory off of the case directory. In the sampleDict file, you give a name to a sample subset and this forms the start of the file name created (the rest being made of the fields). I made use of gnuplot in the tutorial I wrote for benchmarking OF and you can see an example of the sample utility used with gnuplot here: http://www.openfoamwiki.net/index.php/Blasius_Flat-Plate_Flow_Benchmark#Running_ the_Case_and_post-processing Good Luck, Mike J. |
Sebastian Gatzka
Well the utility is creating the timestep-directories, but they are all empty.
Where do I have to state the name of the sample subset? Is It usefull to post the sampleDict file? If so, here it is: // FoamX Case Dictionary. FoamFile { version 2.0; format ascii; root "/home/sega/OpenFOAM/sega-1.4.1/run/tutorials/solidDisplacementFoam"; case "plateHole"; instance "system"; local ""; class dictionary; object sampleDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // arguments "/home/sega/OpenFOAM/sega-1.4.1/run/tutorials/solidDisplacementFoam/plateHole" off off off; interpolationScheme cellPoint; writeFormat raw; sampleSets ( uniform { name leftPatch; axis distance; start (0 0.5 0.25); end (0 2 0.25); nPoints 100; } ); fields ( sigmaxx ); // ************************************************** *********************** //
Michael Jaworski
Sebastian,
In the sampleDict file you quote, the "name" of the sample subset is "leftPatch". The fields that you are sampling is "sigmaxx". When you run the sampl utility, it should make some file called: leftPatch_sigmaxx.xy or something like that. Are there any errors when you run the sample utility itself? Also, there are sometimes problems with the sample utility when it's placed on top of or along the edges of some elements. Try moving it in a small amount: ... sampleSets ( uniform { name leftPatch; axis distance; start (0.05 0.5 0.25); end (0.05 0.5 0.25); nPoints 100; } ); ... |
Sebastian Gatzka
Yes. sigma.component(0) is working.
But why is it stated otherwise in the tutorial? Now, I have files in each timestep-directory called leftPatch_sigma.component(0).xy But how can I plot these files? I really don't get I out of the tutorial. Thanks.
Michael Jaworski
Sebastian,
The tutorial says you should use the sigmaComponents utility before using sample. The output of the sample utility is an ASCII data file with the first column (if you chose distance) as the distance along the line you defined by the points start and end. The other columns are the fields you sampled (sigma.component(0) or sigmaxx). If you need help with using gnuplot, their website has several demos and tutorials can be found online: http://www.gnuplot.info/ Good Luck, Mike J. |
Sebastian Gatzka
Yes, you are right.
I haven't run sigmaComponents before running sample. But the tutorial is rather sloppy there. It's not explaining where to find the sigmaComponent utility in FoamX. Maybe thats the cause I wasn't running it. I think I will visualize the sample data with MATLAB rather than gnuplot. I'm much more familiar with this. BTW: Which plotting tool seems to be most professional for publications?
#9 |
Hi forum members,
I'm new user of OpenFoam, less than 2 months experiences. But i'll say that openFoam is really great and fun. I'm using flow around a square cylinder as a my case study. I have done the pre-processing and solving the case using icoFoam. Now, i'm in the stage of doing post-processing. I extensively using paraFoam to do this. However, i could not find the way to plot velocity fields at the center of every grid cell that i interested in. Instead of doing in paraFoam, i utilize the sampleDict by giving the specific coordinate of the center grid cell. Here is the example of how i calculate the coordinate position (mesh grading: simpleGrading); ================================================= matlab command: N = 100 % number of cell in x direction M = 100 % number of cell in y direction lx = 20 % length of total cell ly = 1 Rx = 0.125 % grading x ratio Ry = 1 % grading y ratio Xs = 0.5 % coordinate first cell Ys = -0.5 % coordinate first cell rx = Rx^(1/(N-1)) ry = Ry^(1/(M-1)) if Rx > 1 alphax = Rx^N else alphax = 1 - rx^(-N) + rx^(-1) end if alphax == 1 deltaSx = lx/N else deltaSx = lx * (rx - 1) / ((alphax*rx)-1) % smallest cell length end deltaLx = deltaSx/Rx % largest cell length for n = 1:N+1 if n == 1 deltax(n) = deltaSx %cell length expand in increase 'n' X(n) = Xs else deltax(n) = (deltax(n-1))/rx X(n) = deltax(n-1) + X(n-1) Xc(n-1) = (X(n) + X(n-1))/2 % Xc is center coordinate of the cell end end if Ry > 1 alphay = Ry^M else alphay = 1 - ry^(-M) + ry^(-1) end if alphay == 1 deltaSy = ly/M else deltaSy = l * (ry - 1) / ((alphay*ry)-1) % smallest cell length end deltaLy = deltaSy/Ry % largest cell length for m = 1:M+1 if m == 1 deltay(m) = deltaSy %cell length expand in increase 'n' Y(m) = Ys else deltay(m) = (deltay(m-1))/ry Y(m) = deltay(m-1) + Y(m-1) Yc(m-1) = (Y(m) + Y(m-1))/2 % Xc is center coordinate of the cell end end ============================================== after i got the coordinate of the center cell, i write it into the sampleDict. Is there any easiest way for me to obtain the flow fields at the specific center of grid cell that i have created? Thank you & have a nice day!! -mali-
mali ![]() |
#11 |
Hi Takuya,
You are right, I could view the center point of every cell together with its vector fields. But I still cannot get the exact coordinate of that cell center and its vector fields value. BTW, could paraView plot the exact cell center coordinate versus velocity fields? Thank you & cheers -mali-
mali ![]() |
#12 |
Takuya OSHIMA
Hi mali,
At least displaying coordinates and vector values is possible. Choose CellCenters1 in the Pipeline Browser and click either Split Horizontal [ | ] or Split Vertical [-] at the top right of the view, and select Spreadsheet View. ![]() But I haven't tried plotting them within ParaView. Takuya |
#13 |
Hi Takuya,
Thank you for the information. It is really help, at least i can compare with my matlab program. ![]() cheers -mali-
mali ![]() |
#14 |
Henrik Bergersen
Hi
I'm having similar problems. I'd like to plot my fields i matlab and for that I need the cell center coordinates. Did you figure out how to export these coordinates from paraView? Or is there another way to get the cell center coordinates? Best Regards Henrik Bergersen |
#15 |
Henrik Bergersen
Nevermind, I got it. (Hint: Save Data in paraView, choose ascii, and then grep&awk).
Henrik |
#16 |
Diauddin Nammari
Good day/evening !
Could someone help please, I have been trying to sample velocity and pressure using the sample command( after setting up the sampledict) The command creates the directory and the files, however there is no data in them. I checked the foam generated files there is data there. I hope someone can help Best regards Diauddin |
#17 |
Johannes Schöön
Hi Diauddin,
Your problem sounds exactly like the one I solved a few minutes ago. The catch here is that as soon as your sampleDict file is OK, the sample utility will run without complaints, even though the data of interest isn't there. For instance, if you want to extract the magnitude of the velocity U, it isn't enough to specify "mag(U)" in the sampleDict file, as you may think after reading the manual, you must ask for "magU" and run "foamCalc mag U" first. It took me one extra night of sleep to figure that one out... Cheers Johannes |
#18 |
Wolfgang Heydlauff
Rep Power: 21 ![]() |
Right. Use
============================================= fields ( p //U //for this run "foamCalc components U" first //Uy //Ux //Uz //for this run "foamCalc mag U" first //magU //for this run "ptot" first //ptot ); ============================================= in your sampleDict |
#19 |
musaddeque hossein
Rep Power: 18 ![]() |
Wolfgang:
Looks like you have had some success with sampleDict. I am trying to run sampleDict in the dambreak tutorial in OpenFoam 1.5 to obtain pressure values along a wall, say leftWall for example. The problem is that the tutorial runs fine, but no files are generated. I posed this problem to the bug report and per Matjis instructions I modified the file to include interpolation and triangulation, but nothing is generated: http://www.cfd-online.com/cgi-bin/OpenFOAM_Discus/show.cgi?tpc=126&post=32641#POST326 41 Any suggestions? Thanks. Musaddeque |
Help with Gnuplot | Sham | FLUENT | 0 | April 23, 2008 02:12 |
Help with GNUPlot | Renato. | Main CFD Forum | 6 | June 6, 2007 19:51 |
gnuplot | Mich | Main CFD Forum | 0 | August 7, 2006 07:30 |
about gnuplot | Tom,L. | Main CFD Forum | 3 | December 30, 2002 13:55 |
Related to using gnuplot | ANIL LAL | Main CFD Forum | 2 | October 22, 1999 11:20 |
