Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Offline forces port processing
Old   November 6, 2024, 07:17
Default Offline forces port processing
Albertine is on a distinguished road
Good morning,
I'm trying to run some offline function objects using the command foamPostProcess after the simulation is completed.
I've written the functions looking a the documents into etc/postProcessing.
I managed to add a probe to get the pressure, but I'm struggling to get forces.
My question is: is it possible to get forces offline?
If yes can you help me?
This is my function and the consequent error:
forces_splitter
type forces;
libs ("libforces.so");
writeControl timeStep;
writeInterval 1;
patches (splitter);
rhoInf 1.225;
CofR (0 0 0)>;
pitchAxis (1 0 0);
rho rhoInf;
--> FOAM FATAL ERROR:
Could not find U, p
From function void Foam::functionObjects::forcesBase::initialise()
in file forcesBase/forcesBase.C at line 186.
FOAM exiting
Albertine is offline   Reply With Quote
Old   November 7, 2024, 04:26
JNSN's Avatar
Jan
JNSN is on a distinguished road
from the documentation (https://doc.cfd.direct/openfoam/user...processing-cli):
This returns the following error message.
--> FOAM FATAL IO ERROR:
request for volVectorField U from objectRegistry region0 failed
The error message is telling the user that the velocity field U is not loaded. For the function to work, both the field needs to be loaded using the -field option as follows.
foamPostProcess -fields "(p U)" -func wallShearStress
Even loading relevant fields, the post-processing fails with the following message.
Unable to find turbulence model in the database
The message is telling us that the foamPostProcessutility has not constructed the necessary models, i.e. a turbulence model, that the incompressibleFluid solver module used when running the simulation. This is a situation where we need to post-process (as opposed to run-time process) using the -solver option modelling will be available that the post-processing function needs.
foamPostProcess -solver incompressibleFluid -func wallShearStress
Note that no fields need to be supplied, e.g. using ”-field U”, because incompressibleFluid module constructs and stores the required fields. Functions can also be selected by the #includeFunc directive in functions file, instead of the -func option.
JNSN is offline   Reply With Quote
Old   November 7, 2024, 09:34
Thank you very much!!
post procesing
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" ds4719 Main CFD Forum 14 February 18, 2022 19:05
Convergence problem of OF WUYing OpenFOAM Running, Solving & CFD 2 September 20, 2021 11:09
Turbine's forces and moments for post processing mxylondon OpenFOAM Post-Processing 1 April 3, 2019 08:30
Residuals and forces spiraling out of control before failing edomalley1 OpenFOAM Running, Solving & CFD 3 September 7, 2018 11:42
[OpenFOAM] Paraview 3.98 - errors when saving geometry file pajot ParaView 1 September 28, 2013 11:45
