Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Sampling planes
Old   September 30, 2024, 12:11
Post Sampling planes
Andilandi is on a distinguished road
I am running simulations with synInflow in OpenFoam 2112 (i am using this old version because synInflow is programmed for it).
I needed the U vectors for the inlet Layer at all time steps in the simulation. I did this with this code:
inletProfiles
type surfaces;
libs ("libsampling.so");
fields (U);
writeControl timeStep;
writeInterval 1;
fixedLocations true;
interpolationScheme cell;
surfaceFormat raw;
surfaces
inletSurfaces
type patch;
patches (inlet);
Then I tried to get U for Planes parallel with the inlet but at other X coordinates, that seemed to work. Here the Code i used:
profiles1
type surfaces;
fields (U);
writeInterval 1;
surfaceFormat raw;
surfaces
profiles1
type plane;
planeType pointAndNormal;
pointAndNormalDict
point (X 0 0);
normal (1 0 0);
triangulate false;
for X i would put the coordinate i want the plane to be. The problem is, if I put X=0 ,in my understanding it should be the same as the inlet Layer? But the Data is different, the coordinates in the Post processing files are the same in both versions, but the values for U are different. Is that normal? What is the explanation?
The most important question is which version is right and how do I fix the other one?
Thanks for helping, I just started with open-foam and don't have that much experience yet
Andilandi is offline   Reply With Quote
libsampling, openfoam 2112, post procesing, sample, sample surface
sampling interval and sampling frequency beauty FLUENT 13 November 9, 2022 09:23
problem sampling a plane in parallel syavash OpenFOAM Post-Processing 0 May 7, 2018 11:15
[waves2Foam] surfaceElevation sampling utilities katakgoreng OpenFOAM Community Contributions 2 November 18, 2016 06:27
Sampling on moving planes Tarak OpenFOAM Post-Processing 1 August 12, 2016 06:43
Calculating average velocity for planes - Confused! nikolasf Visualization & Post-Processing 0 April 23, 2013 10:56
