July 9, 2024, 08:05 |
Failed lookup of a scalar field
Edoardo Taglialatela
Hello Foamers,
I wrote a function to calculate the center of mass coordinates and its velocity components of a certain phase of the simulation. The problem is, with my current function (ran with the command postProcess -dict system/postProcessDict) the terminal shows the following error: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2312 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _e651d635-20240208 OPENFOAM=2312 patch=240220 version=2312 Arch : "LSB;label=32;scalar=64" Exec : postProcess -dict system/postProcessDict Date : Jul 09 2024 Time : 13:54:51 Host : wk-edo PID : 18761 I/O : uncollated Case : /home/edot/Edo/hybridCentralSolvers-edo-problem/Tutorials/vofTwoPhase/case nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Using dynamicCode for functionObject drift at line 22 in "functions/drift" Could not load "/home/edot/Edo/hybridCentralSolvers-edo-problem/Tutorials/vofTwoPhase/case/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libdrift_d69c3e8a2b0f016d7dc9440af280ccb93b370573.so" /home/edot/Edo/hybridCentralSolvers-edo-problem/Tutorials/vofTwoPhase/case/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libdrift_d69c3e8a2b0f016d7dc9440af280ccb93b370573.so: cannot open shared object file: No such file or directory Creating new library in "dynamicCode/drift/platforms/linux64GccDPInt32Opt/lib/libdrift_d69c3e8a2b0f016d7dc9440af280ccb93b370573.so" Invoking wmake libso /home/edot/Edo/hybridCentralSolvers-edo-problem/Tutorials/vofTwoPhase/case/dynamicCode/drift wmake libso /home/edot/Edo/hybridCentralSolvers-edo-problem/Tutorials/vofTwoPhase/case/dynamicCode/drift ln: ./lnInclude dep: functionObjectTemplate.C Ctoo: functionObjectTemplate.C link: /home/edot/Edo/hybridCentralSolvers-edo-problem/Tutorials/vofTwoPhase/case/dynamicCode/drift/../platforms/linux64GccDPInt32Opt/lib/libdrift_d69c3e8a2b0f016d7dc9440af280ccb93b370573.so Time = 0 Reading fields: Executing functionObjects Time = 1e-06 Reading fields: Executing functionObjects --> FOAM FATAL ERROR: (openfoam-2312 patch=240220) failed lookup of volumeFraction1 (objectRegistry region0) available objects of type volScalarField: 0() From const Type& Foam::objectRegistry::lookupObject(const Foam::word&, bool) const [with Type = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>] in file /usr/src/packages/BUILD/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 628. FOAM exiting |
alpha, center of mass, failed lookup, multiphase, postprocess |
implementation of AUSMpw in OpenFOAM | sanjeev_adhikari | OpenFOAM Programming & Development | 0 | October 29, 2021 06:09 |
Issue symmetryPlane 2.5d extruded airfoil simulation | 281419 | OpenFOAM Running, Solving & CFD | 5 | November 28, 2015 13:09 |
dieselFoam problem!! trying to introduce a new heat transfer model | vivek070176 | OpenFOAM Programming & Development | 10 | December 23, 2014 23:48 |
Problems installing OpenFOAM 2.3.0, 1.6-ext and foam-extend 3.0 | sam.ho | OpenFOAM Installation | 35 | April 5, 2014 15:31 |
Convergence on anisotropic tetahedral meshes | pbo | OpenFOAM Running, Solving & CFD | 12 | December 14, 2010 11:59 |
