Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Why can't my tracer line show up?
Old   July 5, 2024, 14:40
Default Why can't my tracer line show up?
yuanjun zou
bean_fighter is on a distinguished road
Hi, I am doing the research on dsmc. I use dsmcFoam to simulate the double lid-cavity. When I finished and try to have the stream tracer, it only shows a little line.
Please help me . Thanks a lot!
bean_fighter is offline   Reply With Quote
Old   July 5, 2024, 14:43
yuanjun zou
These are the photos
Old   August 14, 2024, 10:58
RGS
Rohit George Sebastian
RGS is on a distinguished road
I don't know what DSMC is. Can you please explain a bit more about what you are simulating, on which part of the domain you need to visualise streamlines and what settings you used to make the streamlines? Are you sure that your mesh and boundary conditions are correct?
Maybe you can try making a slice of velocity with LIC instead of plotting streamlines?
RGS is offline   Reply With Quote
dsmcfoam, tracer
parallel run error cma-permission-denied supvato OpenFOAM Running, Solving & CFD 3 October 10, 2022 05:48
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM Ancioi OpenFOAM Meshing & Mesh Conversion 17 January 9, 2019 00:50
[OpenFOAM] Take derivative of mean velocity in paraFoam hiuluom ParaView 13 April 26, 2016 07:44
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
Problems of Duns Codes! Martin J Main CFD Forum 8 August 15, 2003 00:19
