Write initial step in same format as other output |
July 2, 2024, 05:35 |
lucy
Hello community,
I am pretty new to using OpenFoam so this might be obvious to some of you but I could not find another thread about this. Right now, my outputs are written every nth timestep into a gridfile format (".asc"). But my issue is, that the first initial time step (0 for me) is ignored when writting the output and not written into the same format. I would want all of the timesteps outputs to have the same format for consistency purposes. The log for the writing is as follows: gridfileWrite gridfileWrite write: automatically writing areaVectorField Us ignoring old areaVectorField Us_0 automatically writing areaScalarField h ignoring old areaScalarField h_0 automatically writing areaScalarField hentrain ignoring old areaScalarField hentrain_0 automatically writing areaScalarField pb automatically writing areaVectorField tau I understand that pb and tau do not have an intial state since they are computed fields but is it possible to get Us_0.asc as an output for example? What do I have to change to get this? Am I missing some obvious knowledge? Is it a prameter in the dicts that I have to change? Does it have to do with the lib that i am using in gridfileWrite? The gridfileWrite is as follows: // Use gridfileWrite function object gridfileWrite { type gridfileWrite; libs (faAvalanche); fields (".*"); secondOrder on; writeOption autoWrite; //writeOption noWrite; //writeOption anyWrite; ncols 426; nrows 258; //xllcorner -5803; //-5000 //yllcorner 219917; //-220000 xllcorner -803; yllcorner -83; dx 10; dy 10; postfix ".asc"; //offset is interpreted such that the same signs than in gridToSTLDict can be used offset (100.0100.00); } // ************************************************** *********************** // And the controlDict is as follows: FoamFile { version 2.0; format ascii; classdictionary; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application myApplication; startFrom startTime; startTime 0; stopAt endTime; endTime 30; deltaT 0.1; writeControl adjustableRunTime; writeInterval 1; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; initDeltaT yes; maxCo 1.0; functions { #include"gridfileWrite" } I would really appreciate your help, greetings, L. |
output file, write |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 14:05 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
