Taha Yasin Akçay
Rep Power: 0 ![]() |
While calculating Force Coefficients using:
postProcessing -func forceCoeffsIncompressible -noZero Code:
Executing functionObjects --> FOAM FATAL ERROR: (openfoam-2312 patch=240220) Could not find U: U or p:p in database From void Foam::functionObjects::forces::initialise() in file forces/forces.C at line 170. FOAM exiting I have the U in each timestep except 0/. Paraview displays the case fine, reconstructPar run perfectly fine. I am trying to run a simple custom rotating propeller. A nod in the right direction or any help would be useful and i can provide any file if it might be helpful. Thank you. |
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" | ds4719 | Main CFD Forum | 14 | February 18, 2022 18:05 |
Drag Force Ratio for Flat Plate | Rob Wilk | Main CFD Forum | 40 | May 10, 2020 04:47 |
ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 11:12 |
Sectional force coefficients | tfuwa | OpenFOAM Post-Processing | 1 | June 27, 2013 06:49 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
