OPENFOAM simul run in server (Linux) yields different velocities in laptop (Windows) |
April 5, 2024, 10:25 |
Anonymous
Rep Power: 2 |
Dear Openfoamers,
I have run an Openfoam simulation in a supercomputer which runs on Linux. The post-processing uses Paraview 5.11.2. However, when I download the data and visualize it in my laptop (much more efficient for post-processing), which has BlueCFD (Windows) from where I can call Paraview (Paraview 5.6.2), I found out that in the corners of my domain (close to the outlets) I have large velocity values nearby. Have you ever experienced something like this? Could this be related to the use of different versions? Perhaps the simulation has any error? I attach a figure where I compare both results (re-scaled to 0-1 m/s). Many thanks in advance for your help. |
April 5, 2024, 10:51 |
Anonymous
Rep Power: 2 |
Dear openfoamers,
For anyone with the same issue, I can confirm this is because the different versions of Paraview. When tested with version 5.6.2. in the server/supercomputer, the velocity peaks also appeared. It took a few days to realise it and re-run simulations, so I hope this helps someone else... Best regards |
Batch scripts | Bdew8556 | OpenFOAM Running, Solving & CFD | 35 | September 21, 2020 03:27 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
OpenFOAM (Linux) in a MS-HPC-Cloud | fossy | OpenFOAM | 6 | September 23, 2010 11:48 |
Linux to Windows (dual boot system) | Alex | Main CFD Forum | 9 | May 3, 2007 03:36 |
udf cannot run in windows but can in linux | ra shmi | FLUENT | 2 | February 14, 2006 12:12 |
