March 28, 2024, 15:02 |
Convergence issue in a simple case
Santi Parera
Rep Power: 7 |
Hi Foamers,
I'm working on a simple VENTURI pipe simulation. I started with a single straight pipe to make sure I was going on the good way. I started with laminar model but the simulation crashed, I understood the case was intrinsically turbulent so after setting up the turbulence model everything worked fine. After this I thought it was ok to go ahead with a single T pipe (no venturi yet) to make sure the mesh was good, etc. I don't understand why I'm having convergence problems since I have run much more complex geometry simulations with any problem. In attached the full case already run and with the residuals written: https://drive.google.com/file/d/1IYn...ew?usp=sharing |
convergence, turbulence |
axial compressor mass flow convergence issue | jyotir | SU2 | 5 | July 5, 2024 10:06 |
Convergence issue on a very simple case | Kalabagh | OpenFOAM Running, Solving & CFD | 4 | March 23, 2024 16:03 |
Issue setting up a case with periodic boundaries | sampy | CONVERGE | 12 | February 10, 2023 15:29 |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 16:13 |
Disabling SIMPLE convergence check in simpleControl.H | Mojtaba.a | OpenFOAM Running, Solving & CFD | 0 | August 8, 2012 18:31 |
