[volFieldValue] the CellZone fields are not visible in Paraview |
March 7, 2024, 06:04 |
Ege Batmaz
Rep Power: 7 |
Hi there,
I am using the 'volFieldValue' function to write fields (U p) of a specific 'cellZone' called 'Box1' during runtime, without writing the fields all over my domain. This writes the fields to my time folders, under names like "U_cellZone-Box1" and "p_cellZone-Box1". So far, so good. However, I cannot visualise these fields in Paraview. I have enabled the "Read zones" and "Copy data to cell zones" options. I can see my cell zone using the Extract Block filter, but I cannot see the fields. I've also tried changing the filenames from "U_cellZone-Box1" to "U" for example, but this hasn't helped. I also run 'foamToVTK -cellZone-Box1 -parallel'. It writes the mesh of the cellZone in VTK format, but not the fields, so the same problem. Do you have any idea how I should manipulate these cellZone fields to visualise them in Paraview? Best regards, Ege This is the function I am using inside my ControlDict: Code:
volFieldValue1 { type volFieldValue; libs ("libfieldFunctionObjects.so"); log true; writeControl runTime; writeInterval 0.005; writeFields true; regionType cellZone; name Box1; operation none; fields ( U p ); } |
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) | chrisb2244 | OpenFOAM Installation | 2 | August 21, 2013 13:24 |
a reconstructPar issue | immortality | OpenFOAM Post-Processing | 8 | June 16, 2013 11:25 |
an odd(at least for me!) reconstructPar error on a field | immortality | OpenFOAM Running, Solving & CFD | 3 | June 3, 2013 22:36 |
[OpenFOAM] Paraview does not display fields | mirko | ParaView | 1 | August 11, 2011 07:19 |
PostChannel | maka | OpenFOAM Post-Processing | 5 | July 22, 2009 09:15 |
