Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
using graphCell openFoam v-10
Old   February 15, 2024, 18:26
Default using graphCell openFoam v-10
Omokayj
7542omokayj is on a distinguished road
Hi there,
I am new to using openFoam and I am trying to achieve some visualization for my results. I am currently using graphcell for sampling data so i can create some plots using gnuplot.
I have been able to achieve this, but i am thinking of some optimization for the way i am currently specifying the line that i intend to get data for.
here is my graphCell dict
Description
Writes graph data for specified fields along a line, specified by start and
end points. One graph point is generated in each cell that the line
intersects.
start (1 0.3 0.5);
end (5 0.3 0.5);
fields (U p);
axis distance; // The independent variable of the graph. Can be "x",
// "y", "z", "xyz" (all coordinates written out), or
// "distance" (from the start point).
#includeEtc "caseDicts/postProcessing/graphs/graphCell.cfg"
the above file works and i am able to get data for the line defined by the start and end points(in red)
Since i need to observe the system at multiple lines, i intend to post process for multiple lines at the same time - such that when i run 'simpleFoam -postProcess' i get the data for multiple lines at once and i can go ahead to plot. This will make it easier to work with several mesh configurations.
My question is How do i define multiple lines in the graphCell dict?
if i cant do it in the graphCell dict , are there other ways to go about this.?
7542omokayj is offline   Reply With Quote
graphcell, openfoam 10.0, sampling data
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
How to develop OpenFOAM with CMake and popular IDEs cosscholar OpenFOAM Programming & Development 0 March 16, 2022 16:17
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
