January 29, 2024, 03:11 |
Segmentation fault
Oscar Zagal
Rep Power: 2 |
Hi everyone
I´m working with the solver chtMultiRegionFoam in the version 20.09 of openFoam for windows, my case is a pipe with water vapor inside, when I want to see the results in Paraview everything is fine until I use "Plot Over Line" just for check the temperature field in the pipe, after i click the button "Apply" Paraview closes instantly and the bash give me the next message: ( 38.544s) [paraview ]vtkGenericDataArray.txx:62 ERR| vtkFloatArray (0x154d5480): Number of components do not match: Source: 1 Dest: 3 /opt/OpenFOAM/OpenFOAM-dev/bin/paraview: line 23: 1263 Segmentation fault PATH="" $path/paraview-launcher -opengl auto -- "$@" Do you know what would be a possible solution? |
'Signal: Segmentation fault (11)' while running openFoam in Parallel Processing | jaymeen721 | OpenFOAM Running, Solving & CFD | 1 | April 10, 2023 19:17 |
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel | francesco | OpenFOAM Bugs | 4 | May 2, 2017 21:59 |
Segmentation fault in SU2 V5.0 | ygd | SU2 | 2 | March 1, 2017 04:38 |
Segmentation fault when running in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 8, 2015 08:12 |
segmentation fault when installing OF-2.1.1 on a cluster | Rebecca513 | OpenFOAM Installation | 9 | July 31, 2012 15:06 |
