How to convert OpenFOAM results to Flow3D post-processing? |
January 28, 2024, 22:28 |
Rep Power: 10 |
In the past I've run simulations in OpenFOAM and due to the client request that wanted the result files to be in ANSYS-Fluent I've simply applied foamDataToFluent . I tried to find if there is any similar procedure that can be used for Flow3D. Anyone who has worked with Flow3D could advise how the post-processing file formats are in that software. And whether OpenFOAM results can be read in that environment. |
January 30, 2024, 22:02 |
Rep Power: 10 |
Perhaps I should have done more research before asking a question here. But here is what I found so far. Please let me know if this will work as unfortunately, I don't have access to Flow-3D software at the moment to check.
In Flow-3D post-processing section says "FLOW-3D POST 2023R2 introduces support for an all-new results file format based on the EXODUS II format, enabling faster postprocessing." I checked Paraview and in "Save Data" I can see one of the file types being supported is "Exodus II", does that mean I can simply open the results if OpenFOAM in Paraview and save the data as Exodus II then open that file in Flow-3D? Appreciate any input. |
About Post Processing of Reynolds Stress with OpenFOAM v9 | watermelon | OpenFOAM Post-Processing | 0 | June 21, 2022 11:19 |
post processing of Kiva results using ensight | vedhusiva | Main CFD Forum | 1 | June 24, 2010 12:36 |
post processing tansient results | blackbody | CFX | 3 | June 4, 2010 02:24 |
OpenFOAm solver, ANSYS post processing | achinta | OpenFOAM | 3 | May 13, 2010 02:54 |
[General] Flow3d post processing with ParaView | Rajiv Kothari | ParaView | 0 | May 24, 2007 09:00 |
