PostProcess velocity field on a offset of a patch |
October 16, 2023, 10:20 |
Bruno
Dear all,
I'm simulating the wind flowfield arround buildings and want to post process the velocity at the buidling surface and the pressure on a certain surface (patch called facade). How would I be able to export binary file which contains the patch pressure and the velocity on an offset as well as the locations of the values? kind Regards Bvdrsche |
post error, surfacefieldsurface, surfaces |
[Other] Wedge patch '*' is not planar | LilumDaru | OpenFOAM Meshing & Mesh Conversion | 7 | September 18, 2024 05:52 |
Patch Velocity Field | FlyBob91 | OpenFOAM Post-Processing | 0 | May 12, 2017 18:28 |
velocity field of MRF, GGI and rotatingWallVelocity | tonky | OpenFOAM Programming & Development | 1 | October 14, 2016 11:04 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
createPatch Segmentation Fault (CORE DUMPED) | sam.ho | OpenFOAM Pre-Processing | 2 | April 21, 2014 02:01 |
