[ERROR] multiphaseEulerFoam postProcess -func |
October 13, 2023, 15:05 |
Guilherme
Rep Power: 10 |
I'm having difficulty to post processing the bubbleColumn case (tutorial) in my OpenFOAM9. I am unable to extract the Q-criteria (Q) or vorticity information. I am also unable to extract data from shearStress (maybe the R in OpenFOAM5?!) to visualize what was modeled and resolved in the simulation. Can anybody help me? Code:
$ postProcess -func vorticity -latestTime /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 9-b456138dc4bc Exec : postProcess -func vorticity -latestTime Date : Oct 13 2023 Time : 15:02:41 Host : "assis" PID : 6763 I/O : uncollated Case : /home/assis/OpenFOAM/assis-9/solvers/TESTES/OUT/TESTE nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 10 Time = 10 Reading fields: Executing functionObjects --> FOAM Warning : functionObjects::vorticity vorticity cannot find required object U of type volVectorField --> FOAM Warning : functionObjects::vorticity vorticity failed to execute. End Code:
$ postProcess -func shearStress -latestTime /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 9-b456138dc4bc Exec : postProcess -func shearStress -latestTime Date : Oct 13 2023 Time : 15:04:01 Host : "assis" PID : 6777 I/O : uncollated Case : /home/assis/OpenFOAM/assis-9/solvers/TESTES/OUT/TESTE nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 10 Time = 10 Reading fields: Executing functionObjects --> FOAM FATAL ERROR: Unable to find compressible turbulence model momentumTransport in the database From function virtual bool Foam::functionObjects::shearStress::execute() in file shearStress/shearStress.C at line 113. FOAM exiting Code:
$ postProcess -func Q -latestTime /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 9-b456138dc4bc Exec : postProcess -func Q -latestTime Date : Oct 13 2023 Time : 15:04:37 Host : "assis" PID : 6778 I/O : uncollated Case : /home/assis/OpenFOAM/assis-9/solvers/TESTES/OUT/TESTE nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 10 Time = 10 Reading fields: Executing functionObjects --> FOAM Warning : functionObjects::Q Q cannot find required object U of type volVectorField --> FOAM Warning : functionObjects::Q Q failed to execute. End |
October 14, 2023, 07:40 |
Guilherme
Rep Power: 10 |
I managed to solve the Q-criteria and vorticity (I included them in controlDict). However, 'shearStress' apparently is in fact for a compressible solver and R has added in turbulenceFields function. I still can't extract the fields for the solver I'm using... OpenFOAM comments that it didn't find the turbulence model. Can someone help me? |
multiphaseeulerfoam, openfoam9, postprocess |
<solver> -postProcess -func yPlus | qutadah.r | OpenFOAM Post-Processing | 10 | August 8, 2023 11:03 |
Question about 'postProcess -func' | Stan Zhou | OpenFOAM Post-Processing | 2 | July 15, 2020 23:53 |
postProcess -field U -func mag, Why it gives error? | Mojtaba.a | OpenFOAM Post-Processing | 5 | April 9, 2020 15:22 |
simpleFoam -postProcess -func R | kaaja | OpenFOAM Post-Processing | 4 | March 29, 2018 18:48 |
of4 Can't pimpleFoam -postProcess -func forcesCoeffsIncompressible | Danubi | OpenFOAM Post-Processing | 3 | July 27, 2017 13:47 |
