October 2, 2023, 17:32
sampleDict failed on very fine mesh case
Yushu
Hello. I've been running a simple 1D traveling wave case using scalarTransportFOAM recently. The mesh is N=80000. When I tried to sample the data, the log.postProcess kept running on creating mesh at t=0 but without any other progress. The log file is below:
| \\ / O peration | Version: v2012 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
Build : _7bdb509494-20201222 OPENFOAM=2012
Arch : "LSB;label=32;scalar=64"
Exec : postProcess -func sampleDict
Date : Oct 02 2023
Time : 16:02:30
Host : tc004
PID : 163045
I/O : uncollated
Case : /fastscratch/linysh/simulations/weno/scalarTransportFoam/linear/f400000
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
I tried to reduce the mesh, and I found sampleDict worked quite well for N<8750; for N>8750, the sampleDict could not have any results but just kept the 'create mesh for time = 0'.
Are there any solutions to make the sampleDict work on large mesh?
