Different result from solver run and CLI of function object |
August 10, 2023, 11:31 |
Rep Power: 3 |
hi,
I'm trying to identify the amount of water passing a plane. to achieve this, I add a functionObject in my controlDict. the function added is shown below. The case is a simpler version of damBreak, which is some water dropping from the air(see attachment). Code:
functions { flux { functionObjectLibs ("libfieldFunctionObjects.so"); type surfaceFieldValue; enabled true; writeControl outputTime; writeInterval 1; writeFields true; name myName; surfaceFormat none; // regionType: patch/faceZone/sampledSurface regionType sampledSurface; sampledSurfaceDict { type plane; planeType pointAndNormal; pointAndNormalDict { point (0.1 0 25); normal (0 0 1); }; interpolate false; } // Operation: areaAverage/sum/weightedAverage/... operation areaNormalIntegrate; fields ( U ); } } Code:
interFoam -postProcess Code:
# Region type : sampledSurface myName # Faces : 178 # Area : 8.900000e+00 # Time areaNormalIntegrate(U) 0.05 (1.601638e+00 0.000000e+00 0.000000e+00) Code:
# Region type : sampledSurface myName # Faces : 184 # Area : 9.200000e+00 # Time areaNormalIntegrate(U) 0 (0.000000e+00 0.000000e+00 0.000000e+00) 0.05 (-2.227504e-04 0.000000e+00 0.000000e+00) 0.1 (-2.932480e-04 0.000000e+00 0.000000e+00) 0.15 (-8.891989e-05 0.000000e+00 0.000000e+00) 0.2 (-1.824714e-03 0.000000e+00 0.000000e+00) 0.25 (-3.951143e-05 0.000000e+00 0.000000e+00) 0.3 (-8.158129e-04 0.000000e+00 0.000000e+00) 0.35 (7.823114e-04 0.000000e+00 0.000000e+00) 0.4 (2.245233e-03 0.000000e+00 0.000000e+00) 0.45 (4.049318e-03 0.000000e+00 0.000000e+00) 0.5 (4.898588e-03 0.000000e+00 0.000000e+00) 0.55 (5.109302e-03 0.000000e+00 0.000000e+00) 0.6 (5.978782e-03 0.000000e+00 0.000000e+00) 0.65 (6.250927e-03 0.000000e+00 0.000000e+00) 0.7 (-2.399643e-03 0.000000e+00 0.000000e+00) 0.75 (-1.127230e-02 0.000000e+00 0.000000e+00) 0.8 (-7.155068e-03 0.000000e+00 0.000000e+00) 0.85 (-1.574159e-01 0.000000e+00 0.000000e+00) 0.9 (1.621918e-01 0.000000e+00 0.000000e+00) 0.95 (-1.254870e-01 0.000000e+00 0.000000e+00) 1 (3.400532e-02 0.000000e+00 0.000000e+00) 1.05 (7.201005e-02 0.000000e+00 0.000000e+00) 1.1 (9.076889e-02 0.000000e+00 0.000000e+00) 1.15 (-2.786471e-01 0.000000e+00 0.000000e+00) 1.2 (-5.048007e-01 0.000000e+00 0.000000e+00) 1.25 (-3.681236e-01 0.000000e+00 0.000000e+00) 1.3 (-5.155362e-01 0.000000e+00 0.000000e+00) 1.35 (-6.984839e-01 0.000000e+00 0.000000e+00) 1.4 (9.784959e-03 0.000000e+00 0.000000e+00) 1.45 (3.927942e-01 0.000000e+00 0.000000e+00) 1.5 (-3.542411e-01 0.000000e+00 0.000000e+00) 1.55 (-2.586261e+00 0.000000e+00 0.000000e+00) 1.6 (-6.864394e+00 0.000000e+00 0.000000e+00) 1.65 (-2.605651e-01 0.000000e+00 0.000000e+00) 1.7 (4.457992e+00 0.000000e+00 0.000000e+00) 1.75 (-3.350072e+00 0.000000e+00 0.000000e+00) 1.8 (-1.535838e+00 0.000000e+00 0.000000e+00) 1.85 (-3.504160e+00 0.000000e+00 0.000000e+00) 1.9 (-9.405926e+00 0.000000e+00 0.000000e+00) 1.95 (-1.448530e+01 0.000000e+00 0.000000e+00) 2 (8.364064e+00 0.000000e+00 0.000000e+00) 2.05 (7.780693e-01 0.000000e+00 0.000000e+00) 2.1 (-2.933097e+00 0.000000e+00 0.000000e+00) 2.15 (-6.424189e+00 0.000000e+00 0.000000e+00) 2.2 (-2.183912e+00 0.000000e+00 0.000000e+00) 2.25 (-6.395861e+00 0.000000e+00 0.000000e+00) 2.3 (-3.685619e+00 0.000000e+00 0.000000e+00) 2.35 (-4.437925e+00 0.000000e+00 0.000000e+00) 2.4 (-1.785322e+00 0.000000e+00 0.000000e+00) 2.45 (4.933389e+00 0.000000e+00 0.000000e+00) 2.5 (4.853685e+00 0.000000e+00 0.000000e+00) 2.55 (-2.499341e+00 0.000000e+00 0.000000e+00) 2.6 (-4.315828e+00 0.000000e+00 0.000000e+00) 2.65 (-1.217215e+01 0.000000e+00 0.000000e+00) 2.7 (-5.688268e+00 0.000000e+00 0.000000e+00) 2.75 (-3.997427e+00 0.000000e+00 0.000000e+00) 2.8 (-2.372049e+00 0.000000e+00 0.000000e+00) 2.85 (-7.069010e+00 0.000000e+00 0.000000e+00) 2.9 (-6.452742e+00 0.000000e+00 0.000000e+00) 2.95 (-1.762354e+00 0.000000e+00 0.000000e+00) 3 (-1.288960e+00 0.000000e+00 0.000000e+00) |
functionobjects, postprocessing; openfoam; |
