Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
visualize materials independently in a mergedMesh
Old   June 29, 2023, 08:28
Question visualize materials independently in a mergedMesh
Julia Docampo
Xulia is on a distinguished road
Hello
I am trying to post-process a solution consisting of two bodies in contact using the tutorial "punch" in solids4foam:
1. identify contact regions, loads, etc.
2. generate two meshes
3. mergeMeshes to have a single mesh
4. assign material properties to mesh using setCells
Although the mesh is merged, we still know the cells corresponding to each region (body1 & body 2). If I visualize it in paraview, I can only select boundary patches independently:
Is there a way to retrieve the original bodies (from the cellSets) and visualize independently body1 and body2 ?
I apologize if the answer is obvious. I have tried using splitMeshRegions -cellSet. It produces the regions inside the solution folder (1 in my case) but it doesn't assign the computed field values (displacement, stress) to each one so I can only visualize the meshes.
Many thanks !!!
Xulia is offline   Reply With Quote
mergedmeshes, multibody, multimaterial, paraview, post-processing
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Adding material to CFX material library marlon CFX 2 October 16, 2016 10:33
error message cuteapathy CFX 14 March 20, 2012 07:45
