Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
how to use ProfilingSummary
Old   June 5, 2023, 14:37
Default how to use ProfilingSummary
Kate Wilson
sugarbeer is on a distinguished road
Hi, I want to do profiling for solver and assembler. I found that in OpenFOAM v2212, there is a post processing command called profilingSummary. The document is attached.
I am using it like this:
(1) copy one example to my path:
cd $FOAM_RUN
cp -r $FOAM_TUTORIALS/incompressible/simpleFoam/pitzDaily .
(2) add the following key words in controlDict:
profiling
active true;
cpuInfo true;
memInfo true;
sysInfo true;
(3) run the following command:
cd pitzDaily
blockMesh
simpleFoam
profilingSummary
The profilingSummary is supposed to generate profiling information at the time step marked with writeInterval. If it works, it should generate profiling files in postProcessing/profiling/[YourTimeStep]/profiling. But using my command above, it did not work. I am new to openFOAM, has anyone used profilingSummary before and know how to use it? By the way, where can I check which time steps are marked with writeInterval?
File Type: png Screen Shot 2023-06-06 at 00.57.21.png (143.5 KB, 1 views)
sugarbeer is offline   Reply With Quote
Old   June 8, 2023, 17:13
Domenico Lahaye
dlahaye is on a distinguished road
Tried the same. Failed.
Anybody?
dlahaye is offline   Reply With Quote
profiling, profilingsummary
