May 10, 2023, 10:54 |
rhoreactingbouyantFoam at openfoam 10
Huang, Ching-Chan
Rep Power: 3 |
The rhoReactingBouyantFoam disappeared after OpenFoam 8. Now, i am using OpenFoam 10, but i want to use rhoReactingBouyantFoam. Then i copy old verion of Openfoam application about rhoReactingBouyantFoam and wmake it, But it shows errors.
Here is old version openfoam from git : https://github.com/OpenFOAM/OpenFOAM...createFields.H Here is my terminal Code:
wmakeLnIncludeAll: running wmakeLnInclude on dependent libraries: wmakeLnInclude error: base directory /opt/openfoam10/src/TurbulenceModels/turbulenceModels/ does not exist wmakeLnInclude error: base directory /opt/openfoam10/src/TurbulenceModels/compressible/ does not exist wmakeLnInclude error: base directory /opt/openfoam10/src/transportModels/compressible/ does not exist Making dependency list for source file rhoReactingBuoyantFoam.C could not open file rhoCombustionModel.H for source file rhoReactingBuoyantFoam.C due to No such file or directory could not open file turbulentFluidThermoModel.H for source file rhoReactingBuoyantFoam.C due to No such file or directory could not open file fvOptions.H for source file rhoReactingBuoyantFoam.C due to No such file or directory could not open file createFvOptions.H for source file rhoReactingBuoyantFoam.C due to No such file or directory g++ -std=c++14 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -I. -I/opt/openfoam10/applications/solvers/combustion/reactingFoam -I/opt/openfoam10/src/finiteVolume/lnInclude -I/opt/openfoam10/src/meshTools/lnInclude -I/opt/openfoam10/src/sampling/lnInclude -I/opt/openfoam10/src/TurbulenceModels/turbulenceModels/lnInclude -I/opt/openfoam10/src/TurbulenceModels/compressible/lnInclude -I/opt/openfoam10/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam10/src/thermophysicalModels/reactionThermo/lnInclude -I/opt/openfoam10/src/transportModels/compressible/lnInclude -I/opt/openfoam10/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam10/src/thermophysicalModels/chemistryModel/lnInclude -I/opt/openfoam10/src/ODE/lnInclude -I/opt/openfoam10/src/combustionModels/lnInclude -IlnInclude -I. -I/opt/openfoam10/src/OpenFOAM/lnInclude -I/opt/openfoam10/src/OSspecific/POSIX/lnInclude -fPIC -c rhoReactingBuoyantFoam.C -o Make/linux64GccDPInt32Opt/rhoReactingBuoyantFoam.o rhoReactingBuoyantFoam.C:34:10: fatal error: rhoCombustionModel.H: No such file or directory 34 | #include "rhoCombustionModel.H" | ^~~~~~~~~~~~~~~~~~~~~~ compilation terminated. make: *** [/opt/openfoam10/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/rhoReactingBuoyantFoam.o] Error 1 Code:
rhoReactingBuoyantFoam.C EXE = $(FOAM_USER_APPBIN)/rhoReactingBuoyantFoam |
February 10, 2024, 10:51 |
did you found a solution?
Marcelo Bassi
I had the same doubt...
Did you find a solution? Thanks! |
openfoam, openfoam10, openfoam8, rhoreactingbuoyantfoam, solver |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
How to develop OpenFOAM with CMake and popular IDEs | cosscholar | OpenFOAM Programming & Development | 0 | March 16, 2022 15:17 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
