Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Script for calculation of drag force and yaw moment of the hull
Old   April 10, 2023, 00:26
Default Script for calculation of drag force and yaw moment of the hull
Alexander Stroganov
CenterRime is on a distinguished road
For calculation of drag force and yaw moment of the hull we build the Python script.
moving and floating catamaran case solver
Main point is how we need understand the pressure data from OpenFoam?
For now that is we understand
1. For incompressible flow (p) it is pressure divided on density.
2. This pressure it is not Pascal or kgs/m2
3. It is not static pressure.
4. In script it is need to use date from surface cell area and normals.
https://www.phanquocthien.org/post-p...using-paraview
5. Para view filters:
# ExtractSurface
#Generate SurfaceNormals
#CellSize (Area)
#CellDataToPointData
6. Result raw data format:
#Point ID,Area,Normals_0,Normals_1,Normals_2,Points_0,Poi nts_1,Points_2,Points_Magnitude,p
Any advice or help how we need understand of OpenFoam pressure data for calculation of drag force and yaw moment of the hull will be really appreciated.
OSBL_GFD.zip
CenterRime is offline   Reply With Quote
pressure and density
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" ds4719 Main CFD Forum 14 February 18, 2022 19:05
