Weird behavior of TKE(K) using kOmegaSST for my case |
April 6, 2023, 16:32 |
Farzad Faraji
Rep Power: 7 |
Hello all
I am using motorbike example to simulate my airfoil like geometry. After simulation velocity field and pressure fields are ok, but TKE(k) field shows weird behavior. it must show higher k in the downstream, but it shows zero k(TKE) in the downstream and in other places it shows higher k(TKE) where in those location k(TKE) must be zero. Also, I have attached larger image for k(TKE) and Oemga filed and it seems that Omega has a singularity point, but mesh and simulation works fine. I will be thankful for any suggestion. Thanks, Farzad |
April 6, 2023, 18:13 |
just added limitedlinear 1
Farzad Faraji
Rep Power: 7 |
The only real difference between my simulation and motorbike is that I have modified fvSchemes a little bit using lomitedlinear 1, where 1 is the coefficient. I have attached the divSchemes to this post.
Thanks Farzad Last edited by farzadmech; April 6, 2023 at 20:51. |
April 6, 2023, 20:59 |
#3 | |
Farzad Faraji
Rep Power: 7 |
ok, I find what was my problem, recalculate k and omega based 2% turbulence intensity and 10% of the Lref(length of my shape) as my turbulent length scale;
Turbulent intensity = 2%*UfreeStream Turbulent length scale = 10%*GeometryLength Thanks, Farzad Quote:
komegasst, openfoam, steady state |
Pressure instabilities with interDyMFoam for the floatingObject case | nbadano | OpenFOAM Running, Solving & CFD | 15 | October 15, 2021 06:35 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 09:02 |
bc's of a komegaSST case | Zymon | OpenFOAM | 11 | July 25, 2010 09:36 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
