Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Wall shear stress output
Old   January 24, 2023, 23:06
Default Wall shear stress output
David712 is on a distinguished road
I am currently using the OpenFOAM v2206 to simulate the flowfield around a sphere under Re=3700~10000. The solver is pimpleFoam.
The pressure distribution and the wall shear stress distribution around the sphere; velocity profile, Mean(u'u') and turbulent kinetic energy k in the downstream are chosen for validation.
The monitors of the velocity profile, Uprime2Mean and the k are already done with set up the fieldfunctions in the controldict.
However, I wonder how to output the wall shear stress around the sphere?
An example of the wall shear stress distribution is shown as follow.
David712 is offline   Reply With Quote
Old   January 26, 2023, 15:03
Federico Zabaleta
fedez91 is on a distinguished road
Once the model finishes, type
HTML Code:
pimpleFoam -postProcess -func wallShearStress
After that you will be able to see the wall shear stress in paraView. Load only the patches where you want to see the stress.
fedez91 is offline   Reply With Quote
Old   January 26, 2023, 21:53
Smile
HTML Code:
Thank you so much. I will try it.
postprocessing, wall shear stress
Wall shear stress for solid phase? qi.yang@polimi.it OpenFOAM Programming & Development 0 February 24, 2020 07:26
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Wall Shear Stress prediction varies with fix y+ Jeeloong FLUENT 0 November 24, 2016 18:17
Exporting wall shear stress in relative frame of reference gotang FLUENT 0 September 15, 2014 11:35
Re: About wall shear stress Mike FLUENT 9 November 17, 2003 15:41
