January 16, 2023, 07:23 |
Cannot find U, p
Rep Power: 11 |
I've imported the forceCoeffsIncompressible via foamGet in the system folder, and made the necessary changes.
When running simpleFoam with functionObjects, the case works fine and writes the required outputs. But when I run "postProcess -func forceCoeffsIncompressible" after running simpleFoam, I get the erro "Cannot find U, p." What is the issue, can somebody point out? Thanks. |
January 19, 2023, 23:00 |
Federico Zabaleta
Rep Power: 10 |
Try:
HTML Code:
simpleFoam -postProcess -func forceCoeffsIncompressible |
January 23, 2023, 13:46 |
Rep Power: 11 |
Works, thanks!
force coefficients, post procesing |
[foam-extend.org] 3.2 Installation in Debian 8.5 | jsm | OpenFOAM Installation | 2 | June 19, 2016 10:53 |
How to make a code parallel? | Bruno Machado | Fluent UDF and Scheme Programming | 15 | May 27, 2016 09:18 |
CFX-Pre problem, pls help!!! | cth_yao | CFX | 0 | February 17, 2012 00:52 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
Problem Building OF on Centos cluster (no admin rights) | CKH | OpenFOAM Installation | 5 | November 13, 2011 06:32 |
