Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
plotting streamline for change in alpha.water
Old   December 14, 2022, 13:49
Default plotting streamline for change in alpha.water
canderous is on a distinguished road
I'm working on some form of the dam break case, and I'm looking to somehow change the data that streamtracer plots, so that it only shows the streamlines where alpha.water changes from 0 to 1 (so just where alpha.water = 0.5?), i.e. only the surface line of the liquid. How can I achieve this?
canderous is offline   Reply With Quote
Old   December 15, 2022, 04:16
M
AtoHM is on a distinguished road
I assume you use Paraview?
Hopefully I understood your goal correctly, you could just create a contour at alpha.water = 0.5. There add surface stream tracer?
https://www.kitware.com/surface-stre...n-vtkparaview/
AtoHM is offline   Reply With Quote
alpha.water, dam break, streamtracer
[OLAFLOW] The OLAFLOW Thread Phicau OpenFOAM Community Contributions 459 September 12, 2024 12:47
multiphaseEulerFoam FOAM FATAL IO ERROR qutadah.r OpenFOAM Running, Solving & CFD 11 December 10, 2021 21:18
Free Surface Ship Flow timfranke OpenFOAM Running, Solving & CFD 322 March 3, 2021 10:04
objects oscillate at high speed causing collapse in Dynamic mesh and overset mesh ca insane OpenFOAM Running, Solving & CFD 0 May 17, 2020 23:35
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
