December 2, 2022, 09:29 |
Skin friction coefficient with simpleFoam
Kermit
Rep Power: 5 |
Dear all,
I'm working on a 2D backward-facing step at with the simpleFoam solver and I'd like to compute the skin friction coefficient on the wall. To do so, I use the non-dimensionalized wall shear stress (with units) obtained with the postProcessing utilities and then I compute as follows: (1) : instead of using the conventional formulation (2) : where is the dimensional form of the wall shear stress. However, as it can be seen in the attached figures, my results are better when I use the conventional formulation and I dont understand why... Does anyone have an explanation for this? Thanks for your help! With Eq. (1): cf.png With Eq. (2): cf_conventional.png |
May 19, 2023, 02:34 |
Rep Power: 7 |
Hi Kermit
Did you find your answer? I almost have the same issue! |
May 22, 2023, 11:46 |
Kermit
Rep Power: 5 |
Hello saturn_K,
I assumed that the first formulation was the correct one, since it is dimensionally good. What do you think of it ? Kermit |
May 22, 2023, 12:34 |
Kermit
Rep Power: 5 |
I'd also like to point out that the following tutorial supports the first relationship:
https://develop.openfoam.com/Develop...FlatPlate/plot Best regards. |
simplefoam, skin friction coefficient, wall shear stress |
Skin Friction Coefficient plot over the suction side of an airfoil | mariofish | OpenFOAM Post-Processing | 2 | October 15, 2019 08:55 |
Fluent-Skin friction coefficient contours problem | ozturk | FLUENT | 1 | June 29, 2019 16:14 |
High skin friction coefficient, | amir7 | FLUENT | 2 | April 22, 2012 18:13 |
Skin Friction and Shockwave evaluate | mosessitio | FLUENT | 0 | May 20, 2011 20:30 |
Macro for skin friction and pressure coefficient | DoHander | Fluent UDF and Scheme Programming | 0 | January 9, 2010 10:18 |
