Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Calculating the drag coefficient at each time step
Old   November 13, 2022, 12:56
Default Calculating the drag coefficient at each time step
VVN
Vijay
VVN is on a distinguished road
Hello All,
I want to calculate drag coefficient at each time step on front face of each obstacle (here 6 buildings). Here is my blockMesh file
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
    (0 0 0)
    (200 0 0)
    (200 150 0)
    (0 150 0)
    (0 0 250)
    (200 0 250)
    (200 150 250)
    (0 150 250)
blocks
    hex (0 1 2 3 4 5 6 7) (50 50 50) simpleGrading (1 1 1)
edges
boundary
    atmosphere
        type patch;
        faces
            (4 5 6 7)
    bottom
        type wall;
        faces
            (0 3 2 1)
    left
        type cyclic;
        neighbourPatch    right;
        faces
            (0 4 7 3)
    right
        type cyclic;
        neighbourPatch    left;
        faces
            (2 6 5 1)
    entry
        type wall;
        faces
            (1 5 4 0)
    exit
        type patch;
        faces
            (3 7 6 2)
    building
        type wall;
        faces
mergePatchPairs
I am able to remove solid domain (buildings) using toposet. Here is toposet file -
       \\/     M anipulation  |
  FoamFile
      version     2.0;
      format      ascii;
      class       dictionary;
      object      topoSetDict;
  actions
          name    c0;
          type    cellSet;
          action  clear;
          name    c0;
          type    cellSet;
          action  invert;
          name    c0;
          type    cellSet;
          action  delete;
          source  boxToCell;
          sourceInfo
          boxes
          (			( 35 50 0 ) ( 65 70 80 )
 			( 85 50 0 ) ( 115 70 80 )
 			( 135 50 0 ) ( 165 70 80 )
 			( 35 100 0 ) ( 65 120 80 )
 			( 85 100 0 ) ( 115 120 80 )
 			( 135 100 0 ) ( 165 120 80 )
But could you please tell me how to proceed further? I have simulated the results and now want to extract drag coefficient.
To try out, I added forcecoeff function in controldict file.
functions
forceCoeffs1
    // Mandatory entries
    type            forceCoeffs;
    libs            ("libforces.so");
    patches         (building);
    // Optional entries
    // Field names
    p               p;
    U               U;
    rho             rho;
    rho         rhoInf;
    rhoInf      1000;
    // Reference pressure [Pa]
    pRef            0;
    // Include porosity effects?
    porosity        no;
    // Store and write volume field representations of forces and moments
    writeFields     yes;
    // Centre of rotation for moment calculations
    CofR            (0 0 0);
    // Lift direction
    liftDir         (0 0 1);
    // Drag direction
    dragDir         (0 1 0);
    // Pitch axis
    pitchAxis       (1 0 0);
    // Freestream velocity magnitude [m/s]
    magUInf         30;
    // Reference length [m]
    lRef            80;
    // Reference area [m2]
    Aref            2400;
    // Spatial data binning
    // - extents given by the bounds of the input geometry
    binData
        nBin        20;
        direction   (0 1 0);
        cumulative  yes;
But here for patching I used 'building' patch which contains all my 6 buildings and this gives wrong results. I want to have drag coefficient for each building. So I will be require to have 6 different patches, if I am correct.
Could anyone tell me how can I create patch for front face of each building which was deleted from topoSet? How can I use createPatch here? And if anyone has different approach, let me know.
Thank you in advance : )
VVN is offline   Reply With Quote
createpatchdict, forcecoeffs, toposetdict
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 42 May 8, 2024 00:17
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
