Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to access the Kla, "KD", in InterfaceCompositionPhaseChangePhaseSystem of MPE
Old   November 2, 2022, 16:51
Default How to access the Kla, "KD", in InterfaceCompositionPhaseChangePhaseSystem of MPE
Shuji Chang
shuji_type97 is on a distinguished road
Hi Foamers,
Thanks for your reading.
I am still at the groping stage of using OpenFoam. I want to access the data "KD" calculated in the InterfaceCompositionPhaseChangePhaseSystem.C of MultiphaseEulerFoam because I want to get the Kla calculated in OpenFOAM and save it in the time folder.
May I ask whether is possible to access it by using mesh().lookupObject method? Actually, I tried that. Cause I know the Saturated Mass fraction, I want to calculate in ControlDict functions it by dividing mass transfer by rho like below:
code
            //Look up the dmdt
            const volScalarField& msp = mesh().lookupObject<volScalarField>("interfaceCompositionPhaseChange:dmidtfSp.O2.gasAndLiquid");
            //Look up the rho liquid
            const volScalarField& rho = mesh().lookupObject<volScalarField>("thermo:rho.liquid");
            volScalarField Kla
               IOobject
                  "Kla",
                  mesh().time().timeName(),
                  mesh(),
                  IOobject::NO_READ,
                  IOobject::AUTO_WRITE
               mesh(),
               dimensionedScalar("Kla", dimless/dimTime, 0.0)
           Kla = msp/rho;
           if(mesh().time().outputTime())
              Kla().write();
No error was reported, but also no output in the time folder. I found in that Head file, dmidtfSp is private. Is this the reason why I cannot access it? I see my method is quite indirect. Is there any way to get the "KD" directly?
Any BIG BOSS could give me some suggestions about doing this?
Best wishes
shuji_type97 is offline   Reply With Quote
Old   November 4, 2022, 19:19
Default Solved
Shuji Chang
Hi Foamers,
Sorry for my stupidity. I make a fool mistake in my code.
in "functionsobjective" of controlDict, there is no block for "code". Now I use codeWrite, and it works.
Best wishes
c++ solver class, controldict., multiphaseeulerfaom
How to access force values calculated by the function object. gigili206 OpenFOAM Programming & Development 1 June 27, 2023 12:15
Access UMean at particular run time absrocks OpenFOAM Running, Solving & CFD 3 July 7, 2021 21:29
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
Why is access to turbulence fields provided as const? mrishi OpenFOAM Programming & Development 3 January 23, 2020 13:51
Is there a way to access the gradient limiter in Fluent ? CFDYourself FLUENT 1 February 16, 2016 06:49
