Why negative wall shear stress for flow past plate? |
TWB
Rep Power: 19 ![]() |
I simulated a simple case of flow past flat plate using simpleFoam 2D. Re is 100 It starts with slip BC 1st before encountering the flat plate wall. I enabled the calculation of wall shear stress too. However, the results on Paraview shows that the wall shear stress x is negative. May I know why this is so? Shouldn't it be positive? There's no flow separation. I have attached a figure |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
Wall shear stress for solid phase? | qi.yang@polimi.it | OpenFOAM Programming & Development | 0 | February 24, 2020 06:26 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Calculating the Wall Shear Stress Gradient over surface | 123catty456 | Main CFD Forum | 1 | October 1, 2012 22:27 |
